Drag Racing Tech
Wheel stud of choice? 1/2"
Old Jul 13, 2008 | 02:58 PM
Black Sunshine/ 00SS's Avatar
Default Wheel stud of choice? 1/2"
Knurled or screw in? This is for a 12" Moser.
Doing the brakes & just want to change, as these have been in there for at least 4 years.
Old Jul 13, 2008 | 03:23 PM
sickss228's Avatar
I run the screw in. If you have knurled now all you need to do is run the correct tap through the holes (1/2x20) srew the new studs in then tack weld them to the axle so they don't back out. You need to tack weld them as you will see they have some play in them because the standard hole for the knurled studs is a bit too large for the tap.
Old Jul 13, 2008 | 11:42 PM
DanZ28's Avatar
If it's track, 5/8". drill and tap em in.
Old Jul 14, 2008 | 05:55 AM
Fireball's Avatar
+1
Old Jul 14, 2008 | 06:02 AM
red83's Avatar
From: sneaking in your back door as you leave!/cartersville ga
5/8-drill and tap. be damn sure you drill them correctly. as it will be a tight fit over the rim
Old Jul 14, 2008 | 07:26 AM
mrdragster1970's Avatar
6 & 8 Second Club
Do it once & never worry again. +3
Old Jul 14, 2008 | 09:37 PM
That's exactly what I did. The bigger ones are on the way.
Old Jul 14, 2008 | 11:37 PM
G&HRacing's Avatar
8 second club
Old Jul 15, 2008 | 04:55 AM
JL ws-6's Avatar
Race your car!
5/8 and be done with it. Only bad part, is you'll never put a street rim on the car again, but for a track car I wouldn't do it any other way.
I went with moroso screw in, nice big locking bolt on the back side to hold them on, no problems at all with them loosening up on me.
Plus if you do still venture out on the street at all, they're one of those things like the battery kill switch, people see that and know you mean business
