SHOULD I RUN 12s WITH THESE MODS???
![Question](https://ls1tech.com/forums/images/icons/icon5.gif)
should i at least be in the high 12s with these mods?
PERFORMANCE
MSD 8.5mm Superconductor spark plug wires
AIT sensor timing advance
K&N CIA
Hypertech Powerstat 160 degree
descreened MAF housing
ported & polished MAF housing
ported & polished TB
TB bump stop mod
TB coolant bypass
gutted catalytic converters
Flowmaster DeltaFlow exhaust system
Shortbelt mod
3.73 rear end gears
ASP underdrive pulleys
Koni Sport shocks
WEIGHT REDUCTION
AIR and EGR delete
PCV delete
EVAP delete
power steering delete
A/C delete
removed bumper reinforcements
removed side impact bars
removed upper panhard rod brace
removed air dam
removed front sway bar
removed spring isolators
removed crossmember brace
removed windshield wiper reservoir
PERFORMANCE
K&N CIA
TB bump stop mod
TB coolant bypass
Shortbelt mod
3.73 rear end gears
Koni Sport shocks
WEIGHT REDUCTION
AIR and EGR delete
PCV delete
EVAP delete
A/C delete
removed air dam
maybe.
But most people who try and take the air dam off have to put it right back on. It forces the air running under the car up to the radiator. I mean, its plastic, so it can't weigh more than 2#...
![Wink](https://ls1tech.com/forums/images/icons/icon12.gif)
ya i know what its there for. ive heard 2 different sides, ive heard of people having probs and people having no probs. i havent had any probs yet. plus, i figured id get decent air to the radiator thru the bumper holes
![Talking](https://ls1tech.com/forums/images/icons/icon10.gif)
ive read alot of post saying removing the air dam and the car wasnt affected in a negative way, especially the post saying they had air coming thru the holes in the bumper cover. makes it easier to run a jack underneath also
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
ya i wanna get hooker super comp longtubes and ory pipe.....and to the guy that said i wasted time and money on my mods, ive barely spent a dime on my mods and time isnt an issue. if cars and modding are your thing, then it is time well spent
Im with him, as far as suggestions, cheap and quick way... Cutout, don't get any of that BS chip stuff, DR's... I think you'll need a converter though.
