P/S Delete Pics?
#61
What fittings work to loop the lines in the factory rack?Is it 1 16mm by 1.5and a 18mm by 1.5 fittings.I want to loop it will steel braided hose and an fittings.just want to be sure before i order them.
#62
yea i bought them thru summit last week. Earls makes them. they have the o-ring and everything. mine were 18mm to -6 an, and 16mm to -6 an and i used some aeromotive hose to connect "loop" the two.
#65
#66
#68
http://store.summitracing.com/checkout/cart.asp
This should be everything you need.
