Drag Racing Tech
How many of you are on 10 bolts?
Old 08-26-2008, 08:43 AM
Unstang's Avatar
Originally Posted by Detroitmuscle
Sounds wicked, whats it typically run with that kinda 60'?
11.20-11.22 on the passes with that exact 60'. Waiting for some good air & I'll try to make it in the 11.teens.
Old 08-28-2008, 04:27 PM
maximusls1's Avatar
1.6's consistently on my TCI 4000 stall.
Old 08-29-2008, 12:57 PM
heymoej's Avatar
404 rwhp,cheapo TSP heads cam package,fast 92/92,pt4000 & FLT lvl4 trans,bmr panhard,lca's & t-arm & gm 373 gears on a auburn in the 10 bolt got me..........
11.08@121 with a 1.48 60'
10 bolt has about 15-20 passes in the 1.5 range for the 60'......
i have not been to the track with the new 85mm lid & 85mm maff & new tune that was 407 rwhp........
Old 08-29-2008, 01:20 PM
Unstang's Avatar
NICE! I knew I should have gotten a PT4000.
Old 08-29-2008, 01:36 PM
MiguelLs1's Avatar
11.72@117 1.61 60 with a best of 1.57. First weekend out with a cam only t/a m6
Old 09-03-2008, 01:48 PM
spec_j's Avatar
stock 10 bolt
330hp
4k stall
1.50 60 foot times
11.7 @ 108 <------ hazed the tires outta the hole
stock 10 bolt
3400 stall + street tires
1.8 60 foot
12.4 @ 110 <----- hooked good
both done with stock H/C, added: LCA's ,Adj PHR and Adj TQ Arm
Old 09-03-2008, 03:11 PM
5_02ls1's Avatar
10 bolt with moser axles and motive 373s 1.6 60 ft 3700+raceweight...
Old 09-03-2008, 09:22 PM
sn8ke eatr's Avatar
im on a second hand 10 bolt that went consistant 11.70's with slicks. now its behind 400wheel hp and is abused daily on dr's but in it i have
eaton posi unit
t/a girdle
moser studs/axels
and the tubes are welded but shes doin fine so far
Old 09-03-2008, 11:22 PM
Rushin's Avatar
3200 stall, local-built 4L60, 3.73s, 1.6 short times, and mileage in sig.
Old 09-04-2008, 07:45 AM
troopercar's Avatar
Headers, ORY,lid, dyno-tuned, 3600 Vigilante converter
70-80 *****-out strip passes most on street tires 10 on dr's, a million street passes
best 60 is 1.74, a bunch of 1.79- 1.85's 113,000 miles on it
I'm very careful not to load/unload the rear, pre-load it to 1200rpm then drop the hammer
But I've not yet begun to defile myself, engine work is coming.
Old 09-04-2008, 09:19 PM
blockheadnic's Avatar
Mods in sig. dynoed 353 n/a and spraying it with a 125 shot. stock 3.23 rear with Mickey DRs. stock stall 11.67et 120 mph 1.89 60ft
Old 09-05-2008, 01:37 PM
  #32
86 IROC's Avatar
Best 60' so far is a 1.69, my car is full weight - spare & jack, full interior, etc. I make mid 400 RW #'s, 275/60-15 MT DR's. Mileage is unknown on the rear, bought it from a local board member, so far so good. It has a MAC girdle cover, I welded the axle tubes, has an LT1/auburn style posi unit, and no name 3.73 gears. It hasn't leaked, and doesn't seem to make any bad noises just yet.
I have a spare rear with GM 3.73's and a used posi from a mid 90's LT1 car. I don't have much money in it, and figure I'll just keep piecing 10 bolts together until I can afford a 12 bolt.
Old 09-17-2008, 02:35 AM
  #33
Red 01SS's Avatar
H/C/SS3600 11.6@117 1.67 60's
Still runnign the stock 3.23's, I launch light'ish' and roll into it. Have not made it to the track yet this year but when I do the plan is to try and break it going for 11.4's or better
Not sure about the number of passes, figure somewhere around 100 or so...
Old 09-17-2008, 02:54 AM
  #34
MeezysHoss's Avatar
420hp M6 SS all motor.....rev to about 2K and ride the clutch out.. usually still spins and then spins again once it gets to 4500K all the way through the rest of the gears, everyone always tells me "throw some E/T streets on there, or at least some nittos!"... but wheelspin is the ten bolts good friend, and when i have a extra 2500 and a trailer at the track.. i will put some boloneys on there and probably snap the rear like a matchstick.... until then i see traction issues and bad ET's in my near future...
Old 09-17-2008, 08:25 AM
  #35
slowmofo's Avatar
1.6 60 foots, 3.42 gears, Yank 3600, MT Dr's, Bolt-ons
I broke a 10 bolt on motor once with just bolt-ons on a 275 MT DR by launching off idle with out preloading the drive train on a 1.72 60'
Snaped 3 teeth off the ring gear
Old 09-23-2008, 01:01 AM
  #36
navyblueSS's Avatar
10.92 @ 126 1.58 60ft on 17in BFG drag radials, 3650 lb. raceweight, and stock 3.23 gears. Rest of mods in sig. Car has around 60 track passes and probably the same amount of street passes. The only mod to rearend is a TA Performance rear girdle. 64,000 miles on rearend and no problems yet
Old 09-23-2008, 08:29 PM
  #37
151ls1's Avatar
Still on the stock 10 bolt. Car has Motive 3.73s, 3600 stall, cam, 125 shot, MT ET Streets, BMR Torque Arm, LCAs w/ reloc. brackets, and basic bolt ons. I have gone 11.26 @ 121 mph. Best 60' has been a 1.66. The car put 350 to the wheels before the 125 shot.
Old 09-25-2008, 12:51 AM
  #38
4psi's Avatar
Mods in my Sig
probably 25 passes on the stock 10 bolt with 3:73 gears and tci 4400 stall
Old 09-29-2008, 07:45 PM
  #39
chrs1313's Avatar
whats the lowest someone has pulled on the stock 10 bolt...
100% stock i have gotten 1.400
Old 09-29-2008, 07:47 PM
  #40
chrs1313's Avatar
we need to get together the next time one of us goes to the track...are cars should be really close...I think i might have to tree you just a hair unless you ran in good DA...
did we ever get a ram air intake on that car...i just made one for another member and it turned out really nice...
it is for a car without ac...the front piece folds down and is attached to the radiator support once in place...just like the one on my car
Quick Reply: How many of you are on 10 bolts?
