Effects of gearing vs. speed
I'm gonna be making enough power here shortly to be trapping low 120's. It will be on N20.
Currently have Nitto 275/40/17's and 3.73 gears. Car is an A4 with a TCI 4000 converter. Tires would be 25.7" tall.
Gonna build my axle to race this season. Was wondering if I needed to step down a ratio to 3.42's so that I don't hit the rev limiter when I'm crossing the traps.
Gear calculator says that in 3rd with the 3.73's 6000 rpm would be 123mph.
In 3rd with 3.42's would be 142mph. Of course that's not taking converter slip or tire growth into account.
I have future plans with the car to go even faster within the next year or two, into the 130-135 range. Would it be worth it to me to change ratios? Would it change how hard the car launches or how it does off the spray?
Oh, and before anyone asks, I don't have tuning software currently, but it's on the short list, so I would have my tuner change the gear ratio, but I wouldn't be able to change tire sizes quickly, so I couldn't run the Nittos on the street, and then a 27" or 28" at the track.
Any advice would be welcome.
Also if you are going to run a 28" tall tire for the track, do just that, use it ONLY at the track. It won't mess with anything but your speedometer, and you shouldn't even have your eyes on it going down the track. (That is if you don't rewire your speedo)
I'm just not sure if they make them for your application though. It would be worth checking into though.
Here is a pic of my car.
when i went from a stock stall to a ss3600 i gained 1mph at the track with all conditions and everything taken into account...you should gain or stay the same with a good aftermarket converter...
now with a cheaply made converter or a fuddle type you are not going to be as efficient...and will lose mph...this is the exact reason i went with yank
EDIT: Duh, look at your sig. I'll probably step down to 3:42's now.
i am shifting around 6600-6700 and am leaving some on the table being 3.23 gears but i am not going to make the 10 bolt any weaker with 3.73s, when i get a 12 bolt i will definitely be getting some 3.73s...4.10s if i go with a 28" tall tires...
i used to shift my SI at 6300...
i think right now i am going through at 4900ish i believe...
...if you got 3.73s in now i would just keep them you should be fine
