Found the limits of a stock 9 inch third member...
(Makes it easy to change the pinion)
That sucks. I would guess it was just a fluke thing. I've seen much faster & heavier cars last a long time with zero problems. Good luck getting it back on the road.
Also would make gear changes easy.
I see it now that is what you have sorry.
I replaced it with a Strange PRO case.
Now all I need is to get rid of the eaton.
Chad
Nimitz87: Wish I would have noticed that myself Nimitz! Could have saved me some headaches... I really thought my driveshaft would have been the weak link. I'm still running a stocker steel with an adapter 1350 u joint... Guess I was wrong!!!
DanZ28: I guess so... Sucks having to spend more money yet on the rear... Should be back out next spring, I can't afford to get it on the road this year because I have one more semester of college to pay for!
When you are beating on 40 year old thin cast parts things can happen. I will be using a through bolt Strange case
We only use the stock housings for road racing
Chad
