Avg. HP loss through Drivetrain?
All fluid robs energy. Every tooth on a gear creates friction. This robs energy. The faster you accelerate the hotter it gets. Heat is energy. Think about it like this. If you have a swimming pool. Stick a skimmer net in there on a pole (the thing you use to get the leaves out). Move it with a constant force against the water, see how much the pole bends. Say the pole bends 2" over 8 foot. Say you put about 20lb of force on that pole when moving the net through the water. Now put 40lbs of pressure on the pole thus moving the pole faster through the water. This WILL bend the pole more as it takes MORE force to accelerate faster through a fluid. The pole will also bend say 4" in 8 foot. It will not only bend 2" though.
The exact same principle applies to every fluid carying piece in your driveline like your rear end, your transmission. The u-joints rob power, even the bearings and the axels.
It is one of the things that is overlooked by most builders. We have had cars that make less power at the crankshaft than others and still manage to win. In a restricted rules class you try to free up all that drag or driveline loss. It's horsepower no matter how you look at it. Once we are at the limit of the combination we find ways to reduce the loss.
We removed the 5th gear in our trans, any weight reduction reduces the power needed to accelerate. Aluminum pressure ring clutches, Aluminum flywheels. Micro Polished trans and rear axle gears. Aluminum driveshaft.
We would run wheels with a 3" backspace so we could narrow the housing an additional 3" each side. Trust me it all adds up.
Also because we raced and maintain our stuff we would run less pre load in the pinion and in the trans. It hurts longevity and strength but that is racing.
The last time we ran at the dyno then installed the engine in the car the loss at the wheels was 8%.
It made over 600 horsepower at the crank so that was 24 horsepower that we had freed up.
Robin
Going by what he was saying answer this for me...
Say you have a 383 that makes 450 HP at 7,500 RPM and you also have a 454 that makes 525 HP at 6,000 RPM. You put both engines in a car with the same drive train, witch one will be robbed of more power?
The 383 is twisting more RPM, therefore more friction and more fluid passing over the gears. so with what he was saying, in this case the lesser power engine would be robbed of more power.
Another thing, you said that every drive line part has an "efficiency" Well, once that part reaches it's point of efficiency wouldn't it stop robbing anymore power?
My old 347ci motor 449rwhp locked / 402rwhp unlocked 8.95%
My new 418ci motor 521rwhp locked / 469rwhp unlocked 9.00%
What about the trans itself and the drum inside. Also the rear.. A lot comes in to play..
Even the engine performance is based on a volumentric efficiency which is a percentage. For instance a gen 1 sbc displaces 350 cu.in. Even with the most advance EFI system that could be run on them it still could never match the LS1 (at 346cu.in) for fuel mileage. It's a more efficient design. It's the same displacement moving the same air in a more efficient way. Efficiency is only ever measured as a percentage. The drivetrain has a negative PERCENTAGE loss of efficiency.
Don't you check post dates???
The 4L85E and 10.5 full floating 14 bolt with a mechanical finger chopper fan eats about 22% in my 97 Express van. The 4L80E and 9.5 semi float 14-bolt with an electric fan setup in my 99 Tahoe eats right at 20%. Losses climb with the square of RPM as well. Down where peak torque happens you may only lose 12%. You have some parts of the driveline that is near a constant power loss such as the fluid pump in the trans and other losses that are variable like friction and oil windage.
Some 01-02 f cars t56 make 300whp give or take. 300x1.13=340 and for Automatic cars of same years are about 10whp less.. 290whp. Using 17-18% from what some like to use for loss.. But for 4l60e trans I like using 17.5%..
So, 290x1.175=340 flywheel.
Long long ago, rule of thumb was higher for automatic cars at 20% dt loss. But trucks with heavier dt parts and taller tires or heavy tires, 12 bolt rears etc.. Will have higher % of dt loss. Along with gears. Cars with over 4.00 will technically read 10whp less on dyno. I have seen difference when I went to 4.10s in my 98 WS6 back in 2010.
