View Poll Results: How much will final tuning w/95 mm tb add to the base of 507/500 ??
1-2
8
21.62%
3-4
6
16.22%
5-6
11
29.73%
7-??
12
32.43%
Voters: 37. You may not vote on this poll
LG Motorsports 402 + Vengeance Ported 92mm FAST = 507 rwhp 500 rwtq first pull !!!
#142
http://forums.corvetteforum.com/c6-t...-flattery.html
Headers look identical see links below Thus the nick name ARH Super Pro
http://lgmotorsports.com/gallery/alb...eaders%202.JPG
http://americanracingheaders.com/C6_Catalog.htm click the third pic...
Odd tube length appears identical and tube routing appear identical
ARH has a right to be pissed (the read from the first link posted)
#143
I'm not defending anyone here nor taking sides but at what point do identical and similar differ? The LGs slip fit into the x-pipe where the ARH are ball and socket. The O2 sensor bungs are different as well and, although I can't see much detail on the ARH website, it looks like the collectors are different also. They are a VERY close design though. I had a similar experience. I took off my 1-3/4" Hooker LTs and replaced them with stepped 1-3/4" to 1-7/8" slip on collector Edelbrocks. The tubes are routed EXACTLY the same. The Edelbrocks just look to be an exact, although larger, version of the Hookers. Now both of these companies make tons of headers and I haven't seen any litigation between them. I think you have to chalk it up to design constraints and people wanting the latest tech like merge collectors, long primaries, stepped primaries, etc. Anyway, sorry about the hijack.
Good luck with the TB allngn_c5..I look forward to seeing an update with actual information, lol.
Larry
Larry
#144
allngn....whats the hold up on your build....just a throttle body change no?
need to get that bitch on....have him put it on the dyno...make a few tweeks to the tune and go drive that bitch home
good luck
good luck
#145
1 Post
#150
1 Post
An embarrasing 12.02 at 123.6 mph with a miserable 2.11 60 footer
I felt had I been able to cut 1.7's and make 3 perfect shifts I'd have been able to see an 11.5xx at 120+ mph. On one of my 2.4 60 footers I was able to squeak out almost 98 mph in the 1/8 th. Unfortunately I don't have any of the slips anymore. I think the 1/4 was 122.xxx on that run. My 123.6 1/4 had a 97.xx mph 1/8. Too bad I couldn't cut a nice 60. Should do better this year with the line lock.
#151
1 Post
BTW 3.42 gearing is not the best choice for the track, 3.73's would've helped a little but I think 3.90's would've been perfect. 4th gear was a dog with the 3.42's. Had the RPM drop from 3 to 4 not fallen out of the power band so bad she'd 1/4 a lot better. With that being said though she's not built with the track in mind. I'll hit the track just to see. Its an awesome trip car that should still get great gas mileage, and make one hell of a statement when I arrive. Also should slap the smug look off the faces of all these high end BMW's and Mercedes. Only this time it will be easier and with a more refined exhaust note, thanks to the LG Big 3.
#152
Allngn
cool...i only got one pass in on mine...stock clutch wouldnt take any more...anyways on drag radials i went 11.57 at 123 on a 1.87 60ft on a messy pass....spun on the 1-2, limiter on the 2-3 and 3-4....looking for high tens next month
changing out my LG pros for a set of ARH 1 7/8 and putting in a Spec twin disk along with a RPM Stage 3 390 diff...also will be on ET streets on 17in speedlines and GTO spares up front for skinnies with MH racemasters on them...hopefully get a 1.6 or better 60ft and do some track tuning and get 10s or close to it
You know where Mt. Clemens is? Thats where im origionally from.
#154
1 Post
That zo6 gearing makes your car a bit quicker. Had you gotten traction you'd have been even quicker, probably 11.15 on a perfect pass.
I think you and your car would love the LGM Big 3. Very refined souding. Did you happen to see my car idle and rev with the system?? Its on youtube and on LG's site. Youtube just do a search for g6x3 and you'll see my car.
