Wow! My FMS 441ci made 884hp/649tq NA
#81
I suppled a template of the outer dimensions of the intake to accommodate Allan specs while fitting under the hood. He built it as requested.
It's a work of art and the engine made the power!
Bob
#86
Thanks for the response.
Any issues with the spark signal breaking up at high RPMS?
Also a question on the oil system. I don't see an external wet sump pump, so I am guessing it is a conventional LS1 style oil pump?
This is a really cool build. You can't beat the power it has made with the parts you have used.
#87
Oil system is Melling's pump, Moroso pan, external oil filter, oil cooler and Accusump
