Wow! My FMS 441ci made 884hp/649tq NA
Old 01-22-2009, 09:57 AM
SlickVert's Avatar
Default Wow! My FMS 441ci made 884hp/649tq NA
FMS built me a 441 NA motor
Allan did an awesome job!
Pictures on the dyno and charts can be found here; http://www.futralmotorsports.com/images/bobdyno/
LS2 Block, with Darton Big Bore 4.185 Sleeves by RED
Callies 4” Crank
Manley Rods
ET Canted Valve Heads
Custom 14.2cr Diamond Pistons
FMS Solid Roller Cam
Jesel Rockers 1.85/1.80 rockers
Beck Sheet Metal Intake with 115mm TB
FMS Tri Y Headers 2"-2 1\8" stepped headers w\merge collectors
Moroso wet sump oil pan\Melling oil pump setup
Moroso Vacuum Pump
FMS/Bob
TQ HP
5000
5100 571 554
5200 572 566
5300 574 579
5400 584 600
5500 596 624
5600 604 644
5700 612 664
5800 626 662
5900 634 712
6000 646 738
6100 649 753
6200 649 766
6300 645 773
6400 641 782
6500 637 789
6600 634 796
6700 632 805
6800 633 820
6900 629 827
7000 628 837
7100 628 849
7200 629 863
7300 624 867
7400 622 877
7500 612 874
7600 607 878
7700 599 878
7800 595 884
7900 586 881
8000 576 877
Old 01-22-2009, 10:29 AM
KCFormula's Avatar
Congrats, Allan is the man! His motor designs consistantly make great power. And his tunes make anything driveable.
Any specs on the cam?
Old 01-22-2009, 10:33 AM
chieftransam's Avatar
wow.. any sound clips?
Old 01-22-2009, 10:40 AM
Black2001z06's Avatar
Sounds and looks like one hell of a motor!
Hope you enjoy that beast man!!!
Old 01-22-2009, 11:09 AM
Avaric3's Avatar
wow, thats some insane numbers!! looks like some very pretty pennies were spent on this setup
Old 01-22-2009, 12:17 PM
pastvertical's Avatar
Russ racing dyno?
Old 01-22-2009, 01:13 PM
LS1Tech Sponsor
Mike@Diablosport's Avatar
Hot Damn....
Old 01-22-2009, 01:18 PM
LS1 SPEED's Avatar
now that's some HP!
Old 01-22-2009, 01:20 PM
ndfrsd6's Avatar
**** man that thing is a beast !
Old 01-22-2009, 01:31 PM
TA1364's Avatar
jesus, 8000 rpm
Old 01-22-2009, 01:33 PM
allngn_c5's Avatar
Wow !!!!!!!!
Old 01-22-2009, 01:34 PM
1.8t's Avatar
Wouldn't those numbers being spit out be crank numbers since that engine was dyno'ed on an engine dyno and not a chassis dyno?
Old 01-22-2009, 02:56 PM
Sigforty's Avatar
They are engine dyno numbers.
Old 01-22-2009, 03:04 PM
registered user
ScreaminRedZ's Avatar
Now those numbers are just silly!
Old 01-22-2009, 04:29 PM
OWN3D BY MY PROF!
Beaflag VonRathburg's Avatar
That's a small fortune in parts. Those headers are super sexy! I'd love to have a set like that. I might have to mimic that design. I'm guessing those springs are in the 1.6xx range in diameter? After spending a small fortune why'd you stick with the wet sump setup?
EDIT: Without seeing the internals are you planning on spraying this or was the 4 inch stroke decision coupled with the wet sump / reduce windage and reduced pistons speeds?
Old 01-22-2009, 05:04 PM
CUR 4 VNM's Avatar
congrats those are some serious numbers. enjoy
Old 01-22-2009, 05:12 PM
bigfatls6's Avatar
Damn what rpm are you going to leave at at the track?
Old 01-22-2009, 05:32 PM
KCFormula's Avatar
I can't believe that yours made the power so early. My 421 (4.125" stroke) w/ a Beck intake made peak power at 8300rpm.
Old 01-22-2009, 05:35 PM
LS1TECH Sponsor
ALLBOTTLE's Avatar
It needs more throttle body, that's why it peaked so early.
Old 01-22-2009, 07:42 PM
SlickVert's Avatar
Here a pic
Attached Thumbnails Wow! My FMS 441ci made 884hp/649tq NA-441-pic.jpg
Quick Reply: Wow! My FMS 441ci made 884hp/649tq NA
