PRC Stage 2.5 5.3l Heads & MS3 Dyno Results
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
LS1Tech Premium Sponsor
Here's quick results from a search that are close to what you're looking for. There are quite a few more floating around on here
Hope this helps!
https://ls1tech.com/forums/dynamomet...3-90-90-a.html
https://ls1tech.com/forums/dynamomet...3-results.html
https://ls1tech.com/forums/dynamomet...-mods-sig.html
https://ls1tech.com/forums/dynamomet...k-numbers.html
__________________
![](https://ls1tech.com/forums/signaturepics/sigpic110569_2.gif)
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
#34
Hope this helps!
So is the MS3 cam better matched with the 5.3heads versus to the LS6 heads?? Seems like the MS3/ported 5.3 head combos are making the same rwhp as MS3/ported LS6 head combos but the MS3/ported 5.3 head combos are making 20-30rwtq.
#35
The problem with the MS3 and LS6's is piston to valve clearance. That's why you don't see many of those combos!
__________________
#36
