Thunder Racing Raptor cam #'s
i am the guy in the red truck /w black 22'z that goes out there with yall
yeas ppost up the mod list
1. Year and model of your car
2. what size motor
3. where was it dyno'd
4. why do you say it is running out of injector if it was only a cam
5. do you have a graph
6. If the intake and TB is your problem, them what type of heads do you have
7. was this a dyno-jet (figured someone would have wanted to know since it is the most common asked question in this section)
8. What is your exact cam specs
9. how does it drive (again, commonly asked question.... LOL)
I believe that is all for now... thank-you
Cam only 420/384 is awesome !!! Or do you have heads too ?? Not knocking you, I just think I might have missed something. Are your running a ud pully and ewp as well, or are you expecting 480-500 rwhp without all boltons ?? Again what heads do you have, and do you have the specs on that cam ?? Very curious.
2. What size motor
3. Where was it dyno'd
4. Why do you say it is running out of injector if it was only a cam
5. Do you have a graph
6. If the intake and tb is your problem, them what type of heads do you have
7. Was this a dyno-jet (figured someone would have wanted to know since it is the most common asked question in this section)
9. How does it drive (again, commonly asked question.... Lol)
i believe that is all for now... Thank-you
ls1 motor w/ ls6 intake and heads(243 CAST), raPtor cam, kooks lt w/ y pipe, bowl blended and back cut valves, patriot double valve springs, ported ls1 tb,7.4 push rods,ls7 lifters,ls6 ported oil pump, double molley timing chain,"CRACKED ROD" ROD BOLTS
it was dyno(dynojet) and tuned by geoff at esp (used to be at thunder's shop). When the tuneing was done my injectors (stock) were at 107% @ 6200rpm, and my intake was pulling as hard vacum from lack of air. THIS CAM WILL CONTINUE TO MAKE POWER TO 6800RPM, MY MOTOR CAN HOLD UP TO 7200RPM WITH MY SET UP. I WILL HAVE GRAPH UP AS SOON AS I FIGURE OUT HOW TO CONVET IT FROM THE DYNOJET PROGRAM
I understand the speculation that it doesn't sound possible by some to get those kind of #'s from my set up but like i said it is what the guy who tuned it and who build think it will do and i'm sure they know a bit more about this than the adverage guy....... They do this for a living and have been for many many years.
If the injectors are at 107%, they are still working like they are supposed to. The only way is if they were "really" maxed out and you couldn't get the AFR where it needs to be above 5500 rpms. I'm guessing this isn't the case.
U guys scared him away!!!!!
Damn i wanna know his secrets!!
