01 ZO6 Tsunami Cam results
#61
#64
LS1Tech Premium Sponsor
That blanket statement is false. Different days, different dyno's, different weather, etc will all affect the SAE vs STD numbers, and it's not always 8rwhp.
__________________
![](https://ls1tech.com/forums/signaturepics/sigpic110569_2.gif)
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
#66
1 Post
In that case he's better off with the ls6 intake. I think ls6 heads flow enough that it would help some bot not as much as if they were ported, or he had some TFS 215's or afr 205's
#67
Yea, that was a blanket statement. I should have worded it saying STD numbers are higher than SAE and if he had his graph SAE corrected, his numbers will be lower.
