Not All 224 Camshafts Are Equal... Engine Dyno Data INSIDE!!
What I get from reading this, is that at most, it's a 10hp difference, but when that gets put into a drivetrain, with a water pump, alternator, powersteering pump, a/c, the difference is going to be closer to 2-3 hp. My question is what type of lobes are on the TSP cam? They've already said that they have 0.200" more lift, what about how aggressive the profiles are?
No ax to grind here, no conspiracy theories, I owe my allegiance to myself and my wife and God (not in that order), so don't lump me in with anyone else.
Who's to say the best dyno was picked for the TSP cam, and the worst for the TR cam? If TSP didn't do that, then they did themselves a disjustice, but again proves my point. I want the 224 cam that is the friendliest on the valvetrain because it appears that once in a car, they'll all make the same power.
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
You sir, are a dumbass. ***** isn't adding anything technical to the thread. He's simply coming on here to bust TSP's ***** with his own opinions, stir up ****, and it's not necessary. You guys (you, your son, and your whole crew) are the biggest bunch of drama queens I have ever seen in my life. Thats why you were all banned here for a while, you couldn't keep the sand out of your vaginas long enough to make an intelligent post. You can't hang around here for more than 1 month without creating drama.
And that my friends is the God's honest truth.
You should be looking at .600>.050 variance and the higher it is the softer the lobe. You'll find that TR proprietary lobes are not that much softer than you think.
Comp XE would be softer and XE-R just a tad steeper.
And while similar 224s will make close to each others power, I did not see a major change in the ones tested.
Like mixing lobes and more overlap; you guys might re-evaluate your arguments.
One thing very valid Jon Bauer stated is that looking at the entire graph and understanding what affects it at different rpms besides cam specs in a combo and how to juggle those parts to get the powercurve you want is the real "magic" or just pure physic knowledge if you like.
I do not agree with Jon's analogy of giving a fish vs teaching to fish for this particular excercise. It's too vague. I don't believe that someone taught you how to size a cam by applying physics and you were able to spec out a real world cam that worked the best on the first try. There is a trial and error factor in there somewhere and there are only 2 ways to learn that. By trying and failing or by learning from other people's failures. If you don't share the specifics of what has or has not worked for you, then there really isn't anything for the rest of us to learn.
And to correct my mistake, it's not 0.200 more lift, it's only 0.020" more lift.
Any comparisons of a cam on a 114 lsa vs 112? My tr224 is the 112lsa (108 icl) variety and to be honest, it's got great midrange through topend pull, but then again, I've maximized my setup.
With that background there are some great (math-heavy) writings that can lead you toward methods of determining how to choose valve events, lifts etc. that will produce the torque/power the engine is capable of. The more you understand about "how engines really work" the easier it is to make your first valve event selection fairly close to optimum, or at least closer than most of your competitors. Of course there are methods of evaluation of your choices, the engine dyno being a good one. Getting really close on your initial design surely cuts down the testing time and expense.
I suggest you look at the first quote in my siggy. If one is really able to think...inside the box, then stepping outside of it may turn on the light. It happens for a few, but not all.
Understanding how engines really work takes a great amount of time and study. It comes easier to some folks than it does to others. Many folks don't have the ambition nor the guts to do the work. Part of the problem, IMO, is the "entitlement mentality" of so many folks. That's a shame, but our society fosters that mentality. More's the pity! In the end, the spoils will go to those who do the work/study or IOW "pay their dues".
I have met one man in my life who could "think like air". Among his many talents was superb port work. I learned a lot from this kid who was almost 40 years my junior. Bret is only 35 years my junior and has a very good knowledge of how things work. He didn't inherit the knowledge, he earned it. This isn't a meant to be commercial nor a lovefest, it is just an observation.
If you want to know what works, spend a few years studying and learn it for yourself. That's what I meant about teaching someone to fish.
Don't expect too many of those who have learned it the hard (right?) way to spoon feed you the answers. Not many will. In fact, if you don't learn the basics yourself you'll need to be spoon fed each and every time you need a new cam.
You can buy into any of this or not. It doesn't matter to me. It is, however, one proven method that works.
Enough, already!
Jon
While this test shouldn't be construed as who has the best 224 Cam, it shows that there is a minimal effect to changing lobes, lifts, LSA etc...
The variance margin between those cams is very small in rwhp on a cam only setup, BUT as mods go on, those minute variances become a bit more pronounced.
Basicaly dynoing same duration cams will all net similar results as seen, it is good learning knowledge for enthusiasts to see and understand what are the effects of making small changes in a cam.
TSP should be thanked for showing the crowd exactly that (something most shops would not waste their $$ on)
To the Mods:
Could we perhaps spend 5 min cleaning this thread so it is just informative? I'm sure you could reduce it by 50%. (being conservative
)The Best V8 Stories One Small Block at Time
When adding a Lid, Pulley, EWP, ported TB, FAST intake or any other mod that adds between 5-10hp we gladly pay $50-$800, so why when TSP shows us a FREE 5-10hp people talk ****??? (free in the sense of buying one cam vs. another)
Is it worth pulling out a TR224 for the new 224/227? Hell no, but for someone purchasing a 224 cam to replace the stocker the better choice would be the one that offers more hp.
More hp is what this game is about correct?
So which one is more aggressive? My guess, the TSP cam is more aggressive. I've got the cam doctor for my TR224, I'd be interested in seeing your cam specs.
TR lobes are proprietary and a bit harsher than XE on intake.
TR 224/224 114 Camshaft= .563"/.563"
TSP 224R 114 Camshaft= .581"/.581"
TSP 224R 112 Camshaft= .581"/.581
Just FYI. Interesting testing though.
