Not All 224 Camshafts Are Equal... Engine Dyno Data INSIDE!!
Old Jul 20, 2009 | 11:43 AM
Jon@Texas-Speed's Avatar
Default Not All 224 Camshafts Are Equal... Engine Dyno Data INSIDE!!
Here's a engine dyno data sheet for you guys to look over. This is where we compared & built baseline data of 224 duration camshafts so we can check advance for best average power & build a nice baseline for our newest LS camshaft.
This comparison shows the following camshafts on the same engine same mods
Thunder 224/224 114 Camshaft
TSP 224R 114 Camshaft
TSP 224R 112 Camshaft
Baseline Stock LS1 Camshaft
From testing we did with these camshafts at different advance points we were able to maximize average power across the board for guys looking for nice hp gains across the board.
After creating these baselines we tested lots of new camshaft combos & settled on the all new TSP 224/227 camshaft using all new custom Texas Speed lobes. The new TSP camshaft is a 224/227 .615"/605 112. This camshaft helps to maximize power potential using 224 intake duration.
*also included is the new 224 TSP lobe as a single pattern** (run 59)
The new 224/227 camshaft is now available for shipping & works great with the PAC Single Springs!!!
Old Jul 20, 2009 | 01:23 PM
chrs1313's Avatar
nice test...what do you got in store next, maybe some head comparisons
Old Jul 21, 2009 | 08:09 AM
allngn_c5's Avatar
Thats a pretty cool and informative comparison. Thanks for sharing. Seems like a lot of people are going back to the smaller cams. This comparsion should help someone who is sitting on the fence go ahead with a cam swap that they have been contemplating.
Old Jul 21, 2009 | 08:36 AM
caviness's Avatar
whats the specs on the rest of the motor??
Old Jul 21, 2009 | 08:45 AM
ScreaminRedZ's Avatar
registered user
Very cool comparison! Can't wait for any others you guys have cooking up
Old Jul 21, 2009 | 11:16 AM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
Today we are starting some more cam testing in the 228º intake duration range. Head comparisons are definitely on the agenda after we're done with the cam only tests
Originally Posted by allngn_c5
That's a pretty cool and informative comparison. Thanks for sharing. Seems like a lot of people are going back to the smaller cams. This comparison should help someone who is sitting on the fence go ahead with a cam swap that they have been contemplating.
Yea, we've seen the market gradually swaying towards the DD type cams and focusing on street manners more and more so we're all over those as well. We've never JUST offered the huge camshafts that set ET records
LS6 intake, stock 853 heads, bone stock LS1 short-block, stock balancer, and Kooks 1 7/8" engine dyno headers.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old Jul 21, 2009 | 12:24 PM
LS1TORQ's Avatar
great work guys! ur def getting serious now with this engine dyno!
Old Jul 21, 2009 | 03:01 PM
Nitroused383's Avatar
So these are setups that normally put down 370-385hp at the rear wheels. I have not seen many cam only setups with 224 cams and no underdrive pulley put down much more than that. Somewhere around 80hp loss for an M6 it looks like, quite interesting.
Also are you guys tuning each setup or just slapping them in there and dynoing?
Old Jul 21, 2009 | 03:14 PM
TrentSS's Avatar
Nice comparison guys but wondering why the dip in torque around 3,800 to 3,900 rpm's? I saw the same thing on the 220R that was posted. Do these cams have no degree advancement in them at all?
Thanks!
Old Jul 21, 2009 | 03:18 PM
470 hp at the crank, with about 20% loss through the drivetrain will net about 370-380rwhp, which would be quite typical for an A4 car with the same mods. They are being tuned to get the AF ratio virtually identical across the powerband for each test and to eliminate unnecessary variables.
__________________
Old Jul 21, 2009 | 03:24 PM
Thanks!
Yes, every aftermarket cam we've tested so far (many of ours and about 6 competitor's so far) have had that dip....only the stock cam did not show it there, but it did have that large dip just earlier in the powerband as seen in the graph above (about 3200-4000rpm whereas the 224 cams all showed it about 3500-4300rpm). That's something we're looking farther into and will be doing more testing on to clean up!
__________________
Old Jul 21, 2009 | 03:48 PM
TrentSS's Avatar
Thanks Matt!
Old Jul 21, 2009 | 03:54 PM
Could that dip have anything to do with the throttle body or headers? Is the throttle body ported at all. Would be interesting to see if it has something to do with primary length.
Old Jul 21, 2009 | 04:01 PM
It is a stock unported TB. It is very likely due to something in the intake and/or exhaust tract...we haven't got into that testing and chasing that issue yet. It is there with the stock camshaft and all though. We've got some new software to do simulations on that calculate intake and exhaust pressures, flow characteristics and velocity, etc as well that will be helping us pin it down I hope.
__________________
Old Jul 21, 2009 | 11:55 PM
black01_WS6's Avatar
I will be keeping my eye out on these new smaller cams.
Do you guys have any new cams for FI yet?
Old Jul 22, 2009 | 04:17 AM
I just noticed you are using 1 7/8" headers. Any chance you could swap over to 1 3/4" headers and see if that takes care of the dip? I'm sure you guys have a set sitting around somewhere.
Old Jul 22, 2009 | 06:18 AM
Kevin01Z28's Avatar
Is the 224/227 listed on your site cause I don't see it. Ive already got some PAC springs just need a cam
Old Jul 22, 2009 | 10:52 AM
We have a ton of headers here, but it's not as easy as just swapping since the dyno is built around these engine dyno headers. One day soon though, we'll get to that and figure out a way to do some header swap tests. We're more focused on cam testing and such currently. But that is a good idea and something we're interested in doing!
__________________
Old Jul 22, 2009 | 11:50 AM
Jason 98 TA's Avatar
Looks like I wont be testing anymore for a day or two. I only test when my D.A. is within 200-250 ft. Even though the numbers are corrected, I've found that's the best way to try to keep testing as acurate as I can.
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old Jul 22, 2009 | 12:02 PM
UCABlackChevy's Avatar
Are these tests done with the full accessory belt or just a belt on the water pump and crank?
