Dyno flatline
Old Jul 22, 2009 | 05:21 PM
OffspringZ28's Avatar
Default Dyno flatline
Hey guys,
check out my graph. it looks there is an abrupt flatline at around 5500rpm. what could cause this? The clutch began to slip a couple days after the dyno and it needed a tune up so I tossed in new plugs and wires. Could this be a valvetrain issue or clutch issue? I was under the impression that a slipping clutch on the dyno would affect trq readings moreso than hp. Thanks for looking!
Old Jul 23, 2009 | 02:36 PM
Mods are stg 2.5 5.3 heads/TR224 @ 114. Full bolt ons if that helps
Old Aug 3, 2009 | 08:47 PM
bizzump
Old Aug 7, 2009 | 11:26 PM
XtraCajunSS's Avatar
What are you running for rocker arms?
Shane
Old Aug 9, 2009 | 04:45 PM
Shane
stock
Old Aug 9, 2009 | 06:37 PM
Slowhawk's Avatar
LS1Tech Sponsor
It could be the clutch,the torque is dropping more than it should too.The dyno operator should of known since the clutch peddle wouldn't come back up after the run.
Old Aug 9, 2009 | 08:36 PM
clutch pedal never really acted up. it just slips now under load in 4th and higher gears
Old Aug 9, 2009 | 10:57 PM
SKINNY69's Avatar
I think you answered your own question.
Old Aug 10, 2009 | 06:36 AM
True lol. I had just never seen a graph with a slipping clutch so I wasn't real sure
