DYNO RESULTS - Patriot LS6 style heads + G5X-3 cam...
Old 11-29-2003, 11:24 PM
  #101
OBSSSD's Avatar
Funny that TAPimp had a friend ask me if I would tune his car when it was ready
I guess I'll let him take it to LG. Maybe the homers can keep the tuning stuff out of the thread. I offered to bet anyone regarding the tuning so unless you're ready to lay down $$$ about the matter then please quit trashing my thread.
Back to the subject....
Regarding geometry - the pushrods are hardened 7.4" and brand new Comp "R" lifters were used with the PP head install per Lou's recommendation. The rocker arms were tightened to the correct specs and the springs were obviously setup by PP. A compression test was done ~ 1 month before the install and everything was good.
The MLS GM head gaskets were used with OE GM head bolt sets and everything was torqued and retorqued to the correct specs. There are no P to V clearance issues at this time.
If the power doesn't increase substantially at Lou's by either tuning or dyno methods used then they are probably coming off in favor of someone else's 5.3L heads to see if in fact that could be the problem. At this point I'm still not sure what to think
Chris
OBSSSD is offline
Old 11-30-2003, 12:32 PM
  #102
gomer's Avatar
Chris
Are you using stock rocker arms? Also, did you have to shim the rockers to get the "loose" preload that the R lifters require?
gomer is offline
Old 11-30-2003, 01:54 PM
  #103
Reboot's Avatar
I think you hit the nail on the head. I bet the Comp R's have too much preload. They seem to like very little.
Reboot is offline
Old 11-30-2003, 01:55 PM
  #104
TApimp's Avatar
yeah i did about two months ago. but then i realized that you were a jack ***, and it made me think otherwise
TApimp is offline
Old 11-30-2003, 02:05 PM
  #105
TVWilkes's Avatar
Chris
Chris,
The crane springs does not require the comp R lifter.They hace 120lbs on the seat and 350 open.
TVWilkes is offline
Old 11-30-2003, 02:56 PM
  #106
01Z0H6's Avatar
Sounds like you have personality issues guy.
Since when did personality override talent?
Chris is very knowledgeable when it comes to the LT1,LT4,LS1/6.
He does this all of the time. I found him to be quite personable myself!
This guy has tuned a ton of Fbod's & C5's to include Z06's.
Again, this is "my" experience with him & rest assured when i do H/C , Tq conv, he'll be there to set it up.
Have you actually met the guy??
01Z0H6 is offline
Old 11-30-2003, 03:17 PM
  #107
TApimp's Avatar
yes, and thats where it all started. i just dont like people who think they know it all. i know i dont know everything. calling yourself "THE" tuner. just makes me laugh
TApimp is offline
Old 11-30-2003, 03:47 PM
  #108
gomer's Avatar
That's what I'm thinking. If he used stock type rockers and 7.4in pushrods, I bet his preload is too much and may be hurting him.
gomer is offline
Old 11-30-2003, 05:22 PM
  #109
DaleMX's Avatar
I know I've seen a thread that said you can run comp lifters with a non adjustable valvetrain, but my guess is that it would be hard to get the 0.0 to .010 preload that the R's like without having a adjustable one.
DaleMX is offline
Old 11-30-2003, 05:53 PM
  #110
6600 rpm clutch dump of death Administrator
J-Rod's Avatar
We're running them (Comp R's) with stock rocker arms and 977s.
J-Rod is offline
Old 11-30-2003, 05:59 PM
  #111
gomer's Avatar
Are your heads milled? What pushrods are you using? Have you checked the preload on yours and did you shim the rockers any?
gomer is offline
Old 11-30-2003, 11:02 PM
  #112
cracker's Avatar
I apologize for the wait on the graph, we were closed most of last week. I will post tomm. afternoon!
cracker is offline
Old 12-01-2003, 12:54 AM
  #113
bigeller's Avatar
To those of you doubting Chris' tuning abilities: DFW is friggin LS1 Mecca. Chris has easily tuned half of the LS1s in the metroplex including some of the fastest in the country.
bigeller is offline
Old 12-01-2003, 03:10 PM
  #114
TApimp's Avatar
who????
TApimp is offline
Old 12-01-2003, 05:35 PM
  #115
cracker's Avatar
For your diagnostic pleasure....
<-Flame Suit On
-Wade
cracker is offline
Old 12-01-2003, 05:47 PM
  #116
Camaroholic's Avatar
FWIW, your 'before' compression check doesn't mean squat right now. You need to do an AFTER check.
If your preload is incorrect (not the torque, the preload), you are hanging valves slightly open when they're supposed to be closed. Even ever so slightly open can have a huge impact on power. My opinion is still that your rocker geometry is incorrect.
I posted earlier in this thread that you should do a compression check. Has it been done yet? I think you will need to do one of 3 things - different length pushrod, shim the rockers, or go with an adjustable valvetrain.
-Andrew
Camaroholic is offline
Old 12-01-2003, 05:54 PM
  #117
TVWilkes's Avatar
-Andrew
I agree,You have to start the check process somewhere.I do not believe the heads are the problem.To many other folks have made good power with the exact same heads.
TVWilkes is offline
Old 12-01-2003, 06:00 PM
  #118
cracker's Avatar
I seriously doubt the problem is the heads. The geometry could be the issue, but I am quandered by these results.
cracker is offline
Old 12-01-2003, 07:27 PM
  #119
bigeller's Avatar
Jay Johnson's all motor setup isn't to shabby..
who????
bigeller is offline
Old 12-01-2003, 10:50 PM
  #120
TApimp's Avatar
yeah if you read his post he put ANOTHER ls1 edit file in it and ran 9.77
who else?
can he tune krispy kreme trucks?
TApimp is offline
Quick Reply: DYNO RESULTS - Patriot LS6 style heads + G5X-3 cam...
