OBSSSD's PP Stg II LS6+G5x3 Dyno Graph
#61
I agree with obssd tottaly, I dont know why everyone goes nuts and recommends the patriots when the clearly do not make that much power. I would rather pay 500-1000.00 dollars more for a head like gtp that makes 40-50 hp than spend 1400 or 1800 on these heads that only make 10 hp. it is not worth the time and effort to ripp apart the car and it is an expensive 1900.00 for patriot ls6 heads to loose power over your old stg1 setup
#62
#63
Originally Posted by Beast96Z
He still never PROVED that the heads are the culprit. The only way to do that is to swap on another set of heads to see if it gains or not. I've seen 4 cars with the 5.3's and the LS-6 style make 440-450 with the TSP 231/237, and one more at 445 with the X-3. The only way to truly tell if it is the heads or not is to pull them and run some tests. If it does turn out to be the heads, I'm sure terry will be more than happy to work something out. I just don't see how one CNC head can be that much diffrent from another. Bashing a sponser without proof is . If you can PROVE that the heads are the problem, I'd be interested to see. Pulling one of the heads and flowing it with the intake on and off would be a good place to start.
If Terry is sure I have his best set of heads then let him state it here and now because then there will be no point in switching for another set of Patriot heads. There are several head porters who are dying to send me a set of heads to switchout, retune, and redyno to see if they can do better. I mean I already lost power on every single car that already had heads on it with no other changes to the car so tell me why I should expect they aren't the problem?
Chris
#66
beast, he lost power over his stg1 5.3l heads, thats proof enough
#67
Originally Posted by LASTLS1
So when are you going to switch the heads (only the heads) and prove your point? There has been plenty of time! Whats taking so LONG? We're waiting. Thanks.
He swapped complete set-ups also. He didn't install just the Patriots and say I lost X amount. Chris, I'm not saying your 6 cars aren't a good excuse, but why would 1 car with similar mods do so well why yours don't. If your saying all the cars lost power, why not post numbers from before and what set-up they were running. You also never answered why the 6 cars you did are so similar in mods and so far apart in dyno numbers. I'm not trying to stir the pot, just stating the obvious.
Terry,
I'll call you tomorrow to discuss the situation
Chris
#68
i really could care less about 424 hp and all that stuff... i just would like to see the times... it dont matter how much hp you have on the dyno as far as im concerned... i just worry about et. have you got any times yet???
#69
6 Second Club Moderator
#70
I just sure hope these 5.3 Patriot's are as good as promised. My car goes in tomorrow to have them installed. I'm looking to get 400 rwhp with my mods. My fingers are crossed at this point.
#71
Originally Posted by OBSSSD
That's easy to say when you aren't the one shelling out thousands of dollars out of your own pocket to fix a problem you shouldn't be dealing with in the first place
For the record yes I did dyno the Patriots on 3 cars with changing just the heads with absolutely no other changes other than tuning the car to 13.0:1 flat with 28 degrees timing and no knock on every car. Against MTI Stage I 5.3L heads they lost 5rwhp, against absolute speed Stage II 5.7L they lost 12rwhp, and against stock LS6 heads they gained 10rwhp. So while I didn't post these intermediate graphs I do have them at the shop because unless you change the heads, dyno, change the cam, then dyno again you can't pinpoint gains or where the lack of gains are
Terry,
Chris
Terry,
Chris
#72
#74
I hope ya get there but with those PP 5.3`s Ive only seen people gaining 20 hp. I hope I am wrong about this but please post your results
#76
1 Post
Damn Chris I was unaware of you guys having issues over there Hope you get it figured out. I am completly satisfied with my Absolute Speed Stage II 5.3's, but you know that already
