Lets see some All Bore and Super Strokers dyno #'s!
I need some motivation here. I am going big, but people rarely post the BIG #'s.. I would like to see thoses graphs or hear those #'s. Please let us know whether you dyno'd on a Mustang Dyno or Dyno Jet.. Compression and what octane fuel would be nice as well..
Well here ya go, I guess Ill be the first. This is an alum block 427 built by JPR. CR is right around 10.8 11.0 . It was done on a Dyno jet and I will run 93 octane. I am very happy with the results. This is an A4 with 12 bolt and 4:11's. Good Luck on your build up. Bear
Here is my 346 graph first.
http://www.ls1camaro.net/freehosting...awk%20Dyno.jpg
Then the 427
http://www.ls1camaro.net/freehosting...awk%20Dyno.JPG
Then the 427
Some very impressive #'s.. Bear you look like you have more in it.. That's a little rich NA. I wonder how it would do around 13 flat A/F.. Linear that is one strong 388ci All Bore.. Not many 427ci's dyno those #'s. It would be good to see a overlay of your dyno compared to a 400ci plus setup.. I would like to see the under the curve..
I have a Cartek built 422 stroker that makes 504 rwhp and 491 rwtq in a C5 with 4.10's and an A4. Runs on 93 octane, and has gone a best of 10.82 @ 127mph. w/1.48 60' time @ 3550 lbs. Motor is for sale, if interested IM me!
Originally Posted by z98
Linear Velocity, those numbers look funny.
478 rwtq @ 5800 rpm = 528 hp
Misprint or something?
Ive got to get a clutch that can hold the power in it before I can dyno :-/ So Im afraid I cant say I have a clue. Feels miiiggghhhty strong up top though I have an all-bore MTI 387 with stage 3 LS6s and an MTI X1 (sort of small cam for the motor size).
A local place has 3 pulls for 25$ on Monday, and its a really nice place. The weather doesnt look great though, so Im not sure I want to pull the car out. :-/ But for 25$, I may just hope the clutch doesnt slip and try it out. :shrug:
chris
chris
Restricted User
I was scared to go with a resleeved motor. There are a lot of horror stories that you don't even hear about. I know of a couple personally built by various shops. Tom the Roofer talked me out of a Big Bore. I went 383 Stroker and am very glad I did... Here is my dyno chart and I have an A4 with a TCI4400 converter and Moser 12 Bolt... This was with a cutout after the Y pipe. I think there are a few more ponies in her. JFM gained almost 15 more hp by dropping the Y pipe. This is a FLP exhaust setup.
For the record, my last sleeved motor never made it to the track. After a tuning session some changes were noted in the oil. the motor was pulled out, and for now its sidelined. I have a 408 iron block in the car right now.
Too bad too.. that motor made some unreal power.
Originally Posted by Linear Velocity
I don't really know where you're getting that calculation from but I'm Not sure, I'm at work I'll have to go home and get the exact peak numbers.
478 X 5800 / 5252 = 527.875xxxxxxxxx
hp is just a calculation of torque, thats why they always cross at 5252 rpm
dyno's measure torque not hp
