Baby EPS cam lays down 430rwhp/415rwtq with track results!
#81
I found this on LS1Tech when I did a search ![Secret2](https://ls1tech.com/forums/images/smilies/LS1Tech/secret.gif)
{You can judge the aggressiveness of a cam by subtracting the advertised duration(.006") from the .050" duration. The typical range will be 49-67. 49 being the harshest and 67 being extremly lazy. A Comp XE lobe will have a diffrence of 53. It still comes off the seat early and provides good low-end power. Springs should make 25-30 k easy, but I would pull one and check it around 20k.}
#83
LS1 Tech Administrator
The ramp rate from .006" to .050" for the EPS lobes is 49 degrees. This is fast, but ramp rate is not the only determining factor in how spring friendly a cam is and how stable it will be at rpm. Acceleration and jerk are much more important factors and it is here where the EPS lobes are superior to the XE-R lobes. Acceleration and jerk are much more controlled with the EPS lobes vs. XE-R lobes even though they match the XE-R lobes at 49 degrees and have more lift.
__________________
![](https://ls1tech.com/forums/signaturepics/sigpic210_1.gif)
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
#85
All this leads to the next question, just how close can a cam grinder hold to the specs?
#87
Anyone running this with an M6? I am looking for a very DD friendly cam to get over 400rwhp. I maybe going to an LS6 longblock as well especially after seeing this numbers with the stock heads.
#92
It offers plenty of torque and the power comes in quick so I think it would push a truck just great. We have only made one trip to the track so far and we were shifting early at 6000 on the 1-2 and 6200 ish on the 2-3. I plan to bump it up on our next trip to see what the car has in it. I'm planning to shoot for 6400-6500 rpm shift points to see if she likes it.
#93
Everyone seems to be getting great deals from them on this board! I am pretty much set on getting the Longblock at this point and a nice small cam like this and being set. All you had to upgrade was the cam and springs correct? Did you also need to do a pushrod change or anything?
#95
excuse my ignorance... people talk a lot about springs breaking and things of that nature after like 15-30k, is there any danger of that with this combo? does it offer as much reliability as stock, or close?
#96
Some great results with that EPS Cam...I need to have them spec me a new cam for my setup. My motor wants more cam/gear lol. I wish our tracks out here had - DA. I ran my 11.2 at +2000 DA with super shitty track prep lol.
#97
You'll never have a cammed car that has the same spring reliability as stock. Unless you go with a very small cam without much lift. Aftermarket cams are harder on springs and springs wear out over time, thats why people say to have the spring pressure tested more often than stock. Intervals depend completely on the valvetrain setup though.
#99
The times are in this thread. Look on page one or two.
__________________
