TSP heads n cam
TSP heads n cam
ok well, long story short ive got a stock bottom end and i am getting ready to order my prc stage 2.5 5.3l heads and a cam package......
my cam choice was the 233/239
i called tsp and the guy told me that that cam was a nitrous cam and if i just wanted a stout N/A motor not to get it because i could make better power with another cam
so.. now im stuck on one of these 3 cams.
Torquer v2
Torquer v3
MS3
what kind of power can i make with this setup?
what do you guys have?
how high do you have to turn them to make max power
Torquer v2
Torquer v3
MS3
I have a similar setup... stock 99 bottom end, GTP stage (whocares but bigger valves) 5.3L heads with a TSP 225/225 112lsa cam.
Originally made 429whp/403wtq on the fresh build. 40k later with no maintanence except oil/filters it threw a valvespring. With new springs and a tune it made 414whp/384wtq. I had dual springs on it when one went, saved the motor as the inner spring kept the valve from falling in, but must have been a bit lazy as it bent a pushrod. Not sure if there was lifter damage, seat damage, etc, but will be redoing the valvejob/heads in the next month and see if we can't reclaim that power.
Sorry, that went kind of long. The point being, you don't need a massive cam to make 400whp with worked 5.3L heads and a good tune.
1 Post
I say custom cam. I've never been happier with my motor then after the custom cam from vengeance racing was installed. More power, better manners, a lot less valvetrain noise, and a stock like idle. I know its hard to believe but no BS. You'll definately do better running a cam that is spec'd around your setup. Good luck.
LS1Tech Premium Sponsor
The 233/239 camshaft will work n/a. I think what the guys are trying to explain over the phone is with the engine dyno testing we've done the Torquer V3 would probably be a better option for your application. With any of the camshafts you choose we'll setup the heads & mill them to meet your requirements & the p/v clearances.
Dont forget about the PRC 215 & 227 heads also, they're not a lot more money, but make awesome power!
http://www.texas-speed.com/shop/item...=1068&catid=40
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Jason
2005 Twin Turbo C6
im running the prc stg 2.5 ls6 heads/tsunami cam combo from them and put down 443whp on the stock ls6 intake/injectors/and didnt have it milled down. i pull alot of cars i dont think i would(175shot 98 cobra, 200shot gto,two different 125 shot bolt on ls1 camaros ect.) highly recommend the setup to anyone
I ran an older version of the 233/239 TSP cam with 62cc AFR 205's and LS6 intake/ported stock TB with FMS red top injectors. Made 439rwhp/385rwtq with 7100rpm redline. A bit soft below 4K but from 4-7K it pulls like a madman. Did a 128.3mph best with this setup at about 3,000lbs with driver.
I liked it..... but a little more midrange would've been better. Run as much compression as you can. ie mill the heads and/or run a thinner head gasket. Check PtV clearance. I milled my heads and had to flycut the pistons (did it myself with a rented tool).
I'm running the 233/239 TSP cam and 5.3 PRC Stg 2.5 heads, and it works fine, even with a lightweight flywheel, however my car only weighs 2750.
No dyno results yet. have plans for this spring.
