5.3 heads guys get in here.
I'm just curious as to know what kind of power you guys make. My car is currently cam only (Torquer 2) and I'm considering doing 5.3 heads in the future. If you post please let me know what compression you're running.
I have a '72SS Camaro LS1 m6 with ms3,stg 2.5 5.3's,ls6 intake,p/p t/b,all bolt ons,e-fans,Mac mids into 3" Dr. Gas X into 2 chamber flows dumped at rear(no cats),8.5" 10 bolt with a locker,msr 30 splines with 4.11's,Monster stg 3 with billet flywheel.Car is 3450lbs with 430rwh/380trq tuned by Geoff Skinner.My best times were 11.53 @ 118mph 1.63 60' 1/4,7.31 1/8 on 28/11.50/15 ET Streets (switched to et drags this yr)I have a new Pat G. custom specd cam to go in (+ a Fast 92/92 & long tubes) with the new EPS Lobes should be here soon!!!Oh ye the hd gaskets were facory mls .052 with 10.75:1 I think( no flycutting was required)Good hds for the $.
TEA 5.3's pred z spec cam (el torro) ls6 intake very loose 4k converter
made 398 380 at the wheels unlocked. el torro is 230/230 no flycutting
10.75 comp. Added ported fast 92 and it really woke up.....Motor pulled very hard.
mods are in my sig. the dyno was not very nice to my set up, but I really don't care. It made 399hp/369tq if I remember right. This was with the LS6 intake and ported throttle body. I have not made it back to the dyno since going to the Fast set up, but I hope to in the next few weeks. The heads were milled .20 and I am running GM MLS head gaskets. I am a little over 11:1 not sure of the exact number. If you do decide to go with 5.3's I would look at the TEA's for sure. Good luck with your decision.
i had a set of older tea 5.3s with a 228r cam and made 436 rwhp, 402 rwtq. that was with a stock fast 90/90, 1 3/4 headers through an m6. milled down to 57 cc so compression was 11:6- 11:7 or so iirc.
I spent 30 mins searching the forum for another member concerning his 228r/LS6 2.5 combo. I found many TEA 1.5 5.3 heads netting low ET's but have average dyno numbers... Most of the TEA combos didn't have huge cams either. Just an observation I made.
Seems like the TEA 5.3 head with a smaller split cam matched to their flow characteristics with a good converter yield stellar results.
$1500 bucks for the TEA 5.3's. If you already have rockers then the Trick Flow "as cast" 220cc heads seem to be a good deal within the same price range. At the same time a good set of ported 243's will give great results too... Decisions. I'd go for the best heads budget allows and design a cam for those particular heads. That's what I've learned after piecing together random parts. I'm done.
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
I have TSP stage 2.5 5.3 heads and a 232/238 6xx 6xx 111lsa cam with a fast 90/90
with a TCI 3500 stall and 3:23 gears I put down 435 rwhp
added 3:37 gears and a 5c(42-4400) stall,and swithed form hedman hedders to hooker 1 7/8 and now put down 426rwhp 407rwt
i'm running tsp 5.3 heads and a 233/239 113 lsa cam with a fast 92/92 setup and 1 3/4 headers. heads are stock 62cc out of the box and cam was installed straight up. Running about 10.7 compression with MLS gaskets. #'s in sig and were also before I got my xpipe and true duals put on.
