forged LS1 LS6 int & TB stock cam - just add T78
This setup is based on a 2002 WS6, stock block, with forged rods and pistons after spinning a rod bearing in the motor a couple years back when I used to spray it. I dropped on 317 heads under the stock LS6 intake and stock hand P&P TB, truck manifolds to 2.5" pipe merged to a T4 flange, with a Precision T78, a Nasty Perf Stage 3 fuel system w/80# injectors, through the T56 and a Moser 9" axle it put down 643WHP/673WTQ on a dynojet @ 13psi on pump gas.
I was very pleased with the numbers it put down. Here's a few vids:
http://www.youtube.com/watch?v=ZZMZqyZhp2M
and a little 2-3 pull
http://www.youtube.com/watch?v=FN91WYwPKEY
