Dyno Tuned "El Torro"
#42
Did you have a base dyno before camming it?
If not, then you have no way of knowing how much the cam gave you and all this speculations are worthless.
Also, did you degree your cam? and I also can deduct that it is not fully tuned.
#43
Im with predator, on not being fully tuned.... also you mentioned that you dont have a ported tb or ud pulley, which is a 10-20rwhp on your camm'd setup. Being locked thought I think something is not lined up right though, if it was unlocked I would say its right on par but get a ported tb & pulley on it and see what that nets you.
#44
well I might have to get myself a ported tb and a ud pulley to reach 400rwhp... but yesterday while driving my car I thought I was hearing a ticking noise coming from the engine... after I washed it I started the car and opend up the hood... well I didn't hear any ticking noise at all... well what I heard was a hissing sound.... within a couple of seconds I found out were that sound was coming from... you will see in the picture.. there is a hole in the tube... so I would say that it has something to do with the idel but I'm not for sure if it would mess with the power or not.. I ordered a tube today from the local GM dealership... so now I guess it's a wait game..
but do you guys think that it would mess with my hp any?
sorry about the quailty of the picture... it was taken with my phone...
![](http://i222.photobucket.com/albums/dd275/najaf4life_photos/IMG_0589.jpg)
#45
yeah your tune is goig to be off that is unmetered air entering the intake...so if it was tuned with the leak and then you close the hole up it could make the car go rich...I can't tell from the picture how big the hole is though...but that is definitely not helping your idle
#46
it's a nice size hole on the bottom of it... if I cover the hole with my finger my car dies.. and I did put a different hose on there and well it doesn't want to idle at all so I just put that one back on...
![](http://i222.photobucket.com/albums/dd275/najaf4life_photos/IMG_0590.jpg)
#48
btw chris those are awesome numbers for you h/c!!!!
#49
i ahd that same problem on mine and it caused my car to almost die at times and i was just lt's intake and exhaust no cam. i raced a buddy with a 07 mustang and he beat me bad, i replaced that hose and i beat him by half a car 2 times in a row the same day lol get it retuned ASAP and let us know, also look at gettin a U/D pulley and P&P TB
#51
well I only paid $11 something for it from a GM dealership.. and I did replace it with just a hose and well it won't idel at all with the different hose on it.. way to rich and it just dies.. but I don't want to replace it unstill I get back to Mike and have him tune it right after I swap it out with the new one. But I'm just wondering if it will give me any more hp once I put the new piece on and he retunes it..
#52
i think you will cause you wont have a vacuum leak there anymore, at least i gained power back when i replaced that little piece.
#53
![Hail](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_hail.gif)
![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
#55
The vacuum leak is a main problem, but more importantly your problem is your stuck on the 400hp mark. If the car runs its *** off with 375 then who cares. Its soooo ricer to gauge the fastness of your car on dyno numbers. Get it retuned and if it makes 380 be happy with it.
I could have had my car tuned a little less rich to hit the 500rwhp mark so i could say it made 500 but it doesnt matter what the number is, it matters how it runs.
#56
#57
well the car got tore apart last night... the dots lined up... so back together the car goes and now just looking into getting a new maf and a tb... hopefully with those two things and that new tube I'll get closer to the 400rwhp mark... I'll let you all know what goes on once I get it tuned again..
#59
IF there was a vacume leak when they tried to tune it your tune is all jacked up which could definetly cause the low hp numbers. Swap the piece and get it retuned. With a good tune it will make more power.
