Dyno Tuned "El Torro"
381 RWHP and 366 RWTQ
dont mean ****!
i have seen more than "2 Ls motors" straight from the factory, be dot to dot and they were retarded by 2 degrees from the factory...
timing chains can most defiantly be marked wrong, even when the factory gets them.
think about it.
why can 2 of the same cars be way faster than the other one.
case in point!
if you feel there is already an issue with the cam set up,
PUT A DEGREE WHEEL ON IT!
There were 15 cause i just unloaded the car off the trailer from coming from the track. I was playing with air pressure at track and 15lbs was were i left them. Next day i started the cam swap. My tuner said he had seen 11-16 hp gain fro tire pressure but not that much. Oh well im happen with it
