Dyno Tuned "El Torro"
and for the idle it should have no problem at all right around 900rpm...it was actually a great street cam...
I hope when you installed it wasnt setup wrong I know it is easy to get mixed up with advancing and retarding the cam with an adjustable timing set...the cam is a 111+4 but I retarded it 2* to get it at 111+2 to gain a hair more ptvc...now it can still be installed straight up and have tighter clearance and push the curve a hair but I think the power is a little on the low side if you have full bolt ons and locked on the dyno...
too bad you didn't do a baseline cause that would help out a ton...
well if I check to see where it was installed at and it is straight up... do you ahve any more ideas on what I should check??
It still wants to die at certain times.. while driving and then coming to a stop some times it will die and other times it is fine.. I also didn't think that I would have to my idel at 850 either... thought I might be able to get it lower than that but if it is any lower the car will die more often.. I will check out my IAC and see what I can find there...
this is very true.. but really am I gonna be able to run mid to low 11's with 375rwhp?? I guess I just really wanna find out if something is wrong with the car or not...
I know that it sucks cause I didn't have a baseline before... I belive the same thing about my low numbers with what I have done while the converter was locked...
no I'm just saying that I wouldn't think that it would have to run the idle at 850 to keep the car running... and even today with what little driving I done.. when I was coming to a stop my car died on me... it doesn't happen all the time but some times...
since the car has been tuned I can tell a little more grunt down low... but there really wasn't that big of a difference from having the new cam installed and tuned before the stock one...
an idle at 850rpm aint bad at all. Try raising it to 900 it should idle a lil smoother.
bottom graph is cam only...
top is new heads and cam
interesting thing to note
@3500rpm he produces 30+tq
@4000rpm " " 30+tq
@4500rpm " " 10+tq
@5000rpm " " 5+tq
@5500rpm " " about the same
@6000rpm " " -25hp
@6500rpm " " -30hp
@6800rpm " " -20hp
