What else can I do for a safe dyno session?
Added a self ported (mostly just cleaned up runners and removed casting flash) Fast 90/90, built trans, yank ss3600, and fresh plugs/wires and went for a dyno tune. First wot was a hair rich still but made 359/340 unlocked with cutouts closed. Peaked at 6000 and was riding out well to 6200+.
Couldn't finish tuning because the car ended up with a transmission case busted in 3 places, driveshaft snapped in half, hole in the floor, and ruined dual exhaust. Transmission had less than 2-3000 miles on the rebuld
Since then I rebuilt the trans, installed a thick walled 3.5" chromoly high speed balanced driveline with spicer solid u joints, and shimmed the trans tailhousing up 3/4-1" for less extreme driveline angle.
Tailhousing is -3* and can not come up any further, pinion angle is right between 0* and +1*
I really want to get the car tuned but cannot afford another failure. What else can I possibly do to make sure I'm safe? I've heard mixed reviews about tuning in 2nd gear. What about just ending the pulls earlier instead of pulling to 6400?
The consensus seems to be that the stock type thin walled 3" necked down to 2.5" low speed balanced driveline was the most likely culprit but I'm still nervous.
I do have a slightly cracked motor mount but the way the mounting brackets are it is nearly impossible and might be impossible to change it without pulling the engine at least partially out of the car.
Go out on the highway and give it a good pull and see if it vibrates. If it does fix the problem before the dyno, if not let it eat.
what do you mean kill me on the street? car has been run like this for nearly 2 years and is basically daily driven. it is my understanding giving both the trans and the pinion the same angle is horribly bad and they should instead be as close to equal but opposite as possible so they cancel each other out
the car has traction bars and does not wheel hop anymore, hooks pretty good with nitto dr
well I have an appointment set up for tomorrow afternoon and must admit I'm nervous as hell because if it goes down again it will be down for a long time, but at the same time can't find anything wrong to signal I should have a problem and it would be nice to have a decent idle, not die so often, and pick up the rest of the power I have on the table
As for the "slightly cracked" mount. U R kidding about a dyno session anyway??
I'm curious to get to the track soon
