whats wrong with this pull >>
Old Jun 18, 2010 | 02:08 PM
lsxmalibu's Avatar
Default whats wrong with this pull >>
did 2 pulls, both have the same thing happen at ~4600 rpm.....
Old Jun 18, 2010 | 02:15 PM
93sspcoupe's Avatar
does the curve have a loop in it going to a lower rpm then a higher one?!?!? looks like it has a nasty miss.
Old Jun 18, 2010 | 02:42 PM
lsxmalibu's Avatar
looks like the engine rpms go down about 100 rpm, then the tq and hp go downhill. On paper that is at about 4600 rpm, but he took it to 5500 and the motor sounded fine.
Old Jun 18, 2010 | 02:46 PM
93sspcoupe's Avatar
if it doesnt miss or anything like that and sounds smooth and clean like you say, then i would have to say the dyno is a pos. put it on a different dyno to see if u get same results
Old Jun 18, 2010 | 03:07 PM
427LS7HCI's Avatar
check your spark plug gaps.
Old Jun 18, 2010 | 03:16 PM
lsxmalibu's Avatar
it was a dyno day, had about 10 cars and mine was the only one.
plugs are gapped at .030", that was about 5psi pull.
Old Jun 18, 2010 | 03:21 PM
93sspcoupe's Avatar
i'd have to say it could be a valve guide problem too. mine did a similar issue on the dyno. guides wore out springs wore out, valves wasnt seating.
Old Jun 18, 2010 | 04:18 PM
Nitroused383's Avatar
Smoothing needs to be set at 5 and some reason the correction factor is set on DIN? Looks like din reads 1.8% higher than SAE. I bet it's just something to do with your torque converter or the way the dyno operator rolled into the throttle. If the car doesn't miss and seems to run fine on the street I would not worry about it at all.
Old Jun 18, 2010 | 07:42 PM
JPH's Avatar
JPH
Id keep looking into the tune.
Old Jun 19, 2010 | 03:36 PM
lsxmalibu's Avatar
I think the tune is close, not perfect but nothing that would cause it to fall off like that
Old Jun 19, 2010 | 05:28 PM
XtraCajunSS's Avatar
Take a look at torque converter or trans issues. I've seen that type of graph when there are issues in the drivetrain such a clutch or converter slippage.
Shane
Old Jun 20, 2010 | 10:21 AM
lsxmalibu's Avatar
thanks, will do.
Old Jun 20, 2010 | 06:07 PM
edcmat-l1's Avatar
CF, DIN is Deutch Industry Standard. Has nothing to do with the shape of the graph.
The loop is a shift, or the converter locking. That's always what it is. Why it looks like **** after the shift is another story.
Old Jun 20, 2010 | 06:36 PM
Slowhawk's Avatar
LS1Tech Sponsor
I agree with a few above.Thats just a bad dyno pull or the converter/tranny messing up.
Old Jun 20, 2010 | 08:10 PM
lsxmalibu's Avatar
its a cheaper converter , no ballon plate, I notice alot of slippage in 3rd gear< rpm go up but mph isnt there.
