Finally got a tune (vid uploaded)
Old Jun 23, 2010 | 01:12 AM
jugz ss's Avatar
Default Finally got a tune (vid uploaded)
Got my car dynoed today. I'll try to post a graph and video once I find out how to post it.
I'm okay with the results. Tell me what you think.
Mods are:
Stock LQ4 block with arp rod bolts with 241's
MS4
SLP LT's & ORY, Magnaflow catback
FAST manifold (not sure if 90 or 78. It came with the car)
SLP below
Aftermarket lid
It made 405rwhp and 387rwt
1st pull
http://www.youtube.com/watch?v=l0nQxz1p0J4
2nd pull
http://www.youtube.com/watch?v=7B-qDURbGOQ
Old Jun 23, 2010 | 11:48 AM
Titanws6's Avatar
Not bad, put a cut-out on that and you'll see some better numbers.
Old Jun 23, 2010 | 02:58 PM
jugz ss's Avatar
Yeah I thought it was okay.
That's what I was thinking of doing. The tuner said I have a couple leaks around the exhaust and that it's holding off some power because of vacuum. I told him I was going to put a cut-out and he suggested to just make the exhaust piping 3inch all the way out because the cut-out isn't good. What do you think?
Old Jun 23, 2010 | 03:12 PM
SWEET98SS's Avatar
Same exact numbers as mine with the cutout open. My numbers are in my sig. What gear do you have? I have 3:42
Old Jun 23, 2010 | 03:34 PM
jugz ss's Avatar
Stock gears.
I'm going to do tb and other little mods im missing to maybe free up more power
Old Jun 23, 2010 | 04:20 PM
SWEET98SS's Avatar
Don't forget underdrive pulley and some sort of ram air
Old Jun 23, 2010 | 06:22 PM
djfury05's Avatar
all you have to do to find out if its a 78 or 90mm FAST is pull off the TB.. its 4 bolts.. a cutout will give you more power but if you are roll racing a lot say up to 125-130 the car will pull harder with it closed because of better back pressure when its closed
Old Jun 23, 2010 | 06:48 PM
Titanws6's Avatar
Cut-outs are good for the dyno and strip, and if you want a loud car. I probably gained 5+hp thru the cut-out vs the magnaflow ( I had one on at one time too). My piping is 3" all the way back from the ORY too. Theres lots of little tricks here and there, but your best bet is to start with your intake and TB and figure out what you have and go from there, that may help alot.
Old Jun 23, 2010 | 07:29 PM
jugz ss's Avatar
Yeah that's on the list as well. I have a ram air kit (don't know the name of it). Its the aluminum plate under the air box that goes in front of the radiator.
Once I pull the TB what do I do. How do I measure or what?
I don't go to the strip much but I would like to get as much out of it as I can. My car is loud enough as it is.
Thanks
Old Jun 24, 2010 | 11:04 AM
djfury05's Avatar
If the snout looks like this then it is a 78mm... if the snout is a larger opening with just a circle gasket it is the 90mm.
(The picture is courtesy of LunarX)
Old Jun 24, 2010 | 02:56 PM
jugz ss's Avatar
Yeah I saw that in the classifieds. Thanks. I'm going to have to check. When I changed my water pump a couple weeks ago I took the TB off and didn't notice it.
Old Jul 1, 2010 | 02:52 PM
jugz ss's Avatar
over 200 views and not many responses
I need opinions.
Is it making a good amount or should i have expected more?
Old Jul 2, 2010 | 12:39 AM
itsslow98's Avatar
my guess is its a fast 90, throw on a set of 243s and youll pick up some good power.
Old Jul 2, 2010 | 02:48 PM
jugz ss's Avatar
if its a 90 would the stock tb still bolt up?
Yeah that's on the list as well. You think its a better option over other heads?
Old Jul 5, 2010 | 01:02 AM
itsslow98's Avatar
depends what the stock TB came off of, if its a 4 bolt then its a 90mm.
Old Aug 2, 2010 | 01:15 PM
Rhino's Avatar
were those stock or ported 241's?
Old Aug 2, 2010 | 06:20 PM
jugz ss's Avatar
Stock. Pm replied to.
Old Oct 29, 2010 | 08:38 AM
01ssreda4's Avatar
Numbers seem low to me.
