Dyno results: EPS cam w/ stock 243 heads.
Cam is 222/226 113 lsa- bolt ons: full exhaust | UD pulley | MTI lid | LS6 intake with 28.8lb inj. Temp was 58*, partly cloudy.
I'll post the graphs after I get it scanned.
I'm not too impress with the tuner that I went with, I dunno. Looking at the graph, he took the conservative route, way conservative.. He even left the rev limit at 6K. He does know his stuff though. He build LS engines for vauxhalls and installs maggie kits and TVS systems and tunes them.
Dynamometer is Dyno Dynamics. I read somewhere that is pretty conservative on the numbers it puts out. I'm not too sure if its this conservative.
The best pull was 488 HP/ 440 TQ, yeah those are the numbers but the one he printed out was 437 HP/ 434 TQ
the catch is: These numbers are the FLYWHEEL.![Barf](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_barf.gif)
I was like WTF? Really? I asked him how are these numbers pulling up were there is one that dynoed 430 RWHP? He said maybe its a happy dyno?
He then showed me the print out of the RWHP which is 357.6 RWHP/ 355 RWTQ. Again that wasn't the max pull, the best pull I saw was 361 RWHP.
The AFR is at 13+ on part throttle til 2.5K RPM then it goes to 12.5 to 11.7 @ 4K rpm and then goes up to 12 @ 4.5K RPM and down gradually to 11.7 again.
He did at least 25+ pulls to dyno tune my car so he meticulously tuned the car up to his standards. The tune is great... maybe not the best performance? The car pulls really well through out the RPM and every shift.![Devil](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_devil.gif)
And for those people who keeps saying every cam and heads you need to upgrade your injectors, FYI: the duty cycle of my inj's at 6K rpm were @ 88%, 28.8lb.![Rolleyes](https://ls1tech.com/forums/images/smilies/LS1Tech/rolleyes.gif)
BTW, does anybody know why my car misfires on NGK iridium plugs? gapped @ .04. Tuner swapped it out w/ NGK copper tip and gapped them to .08 and purrs on idle.
Oh and I have vids. I'll post them as soon as I get them DL'd to youtube.
![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
It says that it was dyno'd in 4th gear, I thought 3rd gear was the standard bc it was the closest to the 1:1 ratio. I think that could be the reason for the low readings.
Edit: I stand corrected, I was thinking Autos...carry on
As soon as the track opens I'll run the car to see where I am at however she's not set up for straight track anymore.
I just wanted to share how fugged up my dyno numbers were.
Z06s obviously have the 243 heads and a cam of similar size, and usually dyno around 355rwhp stock and 380rwhp with headers
I have seen many 224/224 cam cars with 243 heads,, LT's, LS6 intake, stock 3.42 gears & 6-speed lay down 430+RWHP over the years.
These newer EPS cams have been laying down awsome numbers & E.T.'s
Yeah, I'm thinking that too. But btw this guy tune his customer's cars as they have all supercharged so he fattens up the fuel up top. I even suggested to add some more timing up mid to top but nothing really changed drastically on the numbers.
As soon as I get my HPTuners started working again with my new laptop, I'll load up the the tune to have the LS1tech's best tuners can dissect my dyno tune.
