Dyno Graph: From 305rwhp to 440rwhp: Stalled A4 H/C LS1
Old 09-01-2010, 11:31 AM
thunderstruck507's Avatar
Who did the tune? Who ported the heads? Have any pics of the headwork?
Nice results!
Old 09-01-2010, 03:00 PM
Squirts11's Avatar
Originally Posted by SSP Racing
EPS Cam???
Yes, the cam was ground on EPS lobes.
Originally Posted by Engine_HP
nice numbers, who ported the heads ?
Nice results!
A mutual friend introduced me to a local SAM grad. He was confident we could make good power without hogging out the ports/runners, all the while not breaking the bank.
I forgot to take pics of the headwork though....sorry guys.
Old 09-01-2010, 03:02 PM
LilJayV10's Avatar
Nice numbers. That bitch should run 10's hooked up.
Old 09-01-2010, 03:10 PM
fatmat80's Avatar
congrats on the numbers..its funny you a4 guys are now putting m6 dyno numbers down..what is the wold coming too???
Old 09-01-2010, 03:16 PM
chrs1313's Avatar
good job man nice power and curve...yes a 6700-6800 shift point looks good to me by looking at the graph...depends on shift extension but that should be fine with that flat hp curve...great results for touched up 243's...
now go get a slip with fall right around the corner
Old 09-01-2010, 03:46 PM
03supercobra's Avatar
Looking good my friend, HP and TRQ curve is beautiful!
Now we need to get you some good suspension parts so we can get you to run a number at the track!
Old 09-01-2010, 03:57 PM
Detoxx03's Avatar
Congrats man. Awesome numbers.
Old 09-01-2010, 04:03 PM
Nitroused383's Avatar
The results are great but it looks like I was wrong on this one about pulling to 7000 + like I thought. I feel there are some things still left in this setup and I really don't know what to think when people don't degree their cam in! The car will rip for sure but I know there is more in it.
Old 09-01-2010, 04:41 PM
I really don't think the fact that it didn't pull to 7000+ came from the fact that he did not degree his cam. I really think his holdback from making power till 7000 was the mild port on the heads, and not having larger primary size on the headers.
Old 09-01-2010, 07:55 PM
chrs1313's Avatar
I doubt the primary size... 1 3/4 here and mine peaked at 6750...we will see here in a few weeks what it puts down/peaks at with these 1 7/8 ARH and custom Y
Old 09-01-2010, 08:11 PM
I should have explained my post a little more, I believe if the heads were opened up a little more combined with larger primary size his power would have carried on past 6700 rpm or so. Obviously his peak power would also have been greater also. We know the intake is not a restriction in his case, at this point.
Im very interested to see what switching from 1 3/4 to 1 7/8 will do on your setup!
Old 09-01-2010, 10:19 PM
  #32
02*C5's Avatar
Congrats that is looking really dam good.
Old 09-01-2010, 10:36 PM
  #33
Squirts11's Avatar
I agree with this, and I actually regret not having a bit more taken out from the intake runners and adding bigger valves. These things would have certainly allowed better breathing up top, but I guess we're all on a budget, and we have to draw the line somewhere...damnit.
I'm feeling greedy lol, but this'll have to do (...until I spray..)
Old 09-01-2010, 10:55 PM
  #34
Photochop's Avatar
You could keep 2nd guessing things all day. But in the end whats a couple hundred rpm or 20rwhp when its making killer power thru the auto and it should run deep 11s all day with some suspension tweaking on a 17" wheel as is. Spray on top of it will be just plain sicko.
Old 09-01-2010, 11:07 PM
  #35
Chris, you gonna have to be satisfied for atleast a little while my friend. Ill punch you if you start a new build in the next 6 months. Next time you can go real big, with big boy part!
Old 09-03-2010, 12:51 PM
  #36
Detroitmuscle's Avatar
Those are awesome numbers, very similar to mine and trust me the car will rip for sure hope you've got a built rear end Also for the spinning to 7K I have yet to see a car with a plastic intake on it make power that high, they all seem to peak right around 6500, ported or not.
Old 09-03-2010, 03:19 PM
  #37
Here is a 418 with a Fast 90 that seems to turn plenty of rpm just fine. If you know what you're doing these plastic intakes will support 7000 rpm with a 346.
http://img.photobucket.com/albums/v4...Bfull_0001.jpg
Old 09-03-2010, 03:51 PM
  #38
chrs1313's Avatar
agreed my cam peaked at 6750 with a slightly different cam and tweaks I am sure it would have been close...
wonder how these 1 7/8 ARH will affect it...
Old 09-03-2010, 05:36 PM
  #39
speed_demon24's Avatar
I can't believe they did a full pull on the baseline run with that a/f.
Old 09-03-2010, 08:15 PM
  #40
that graph peaks again as I stated around 6500rpms mine does the same with a stock LS6 intake you shift about 200rpms after peak, why wind it out further unless your hitting the limiter on the big end? My point is why get a cam that peaks any higher than what the intake and heads will flow? If your not still climbing to 7K your cam is peaking too high and I haven't seen any graphs peaking higher than that with a fast or ls6 intake.
Quick Reply: Dyno Graph: From 305rwhp to 440rwhp: Stalled A4 H/C LS1
