highest dyno through stock WS6 exhaust
What have you guys seen as the highest dyno through a stock WS6 exhaust? How much did you gain through the cutout?
Cheers,
Chris
Cheers,
Chris
Cheers,
Chris
Cheers,
Chris
Originally Posted by Spellbound
Not quite stock, the I pipe was replaced with about 2 feet of 3 inch pipe when I had my cut out removed.( I lowered the car and tore it up) I dynoed 428 with the stock muffler.
thanks!
what was your combo?
thanks!
thanks!
MMS 229/229 114
Volant intake(since changed back to a MTI lid)
EWP
ASP
FLP's, W/ orp's
YT's
It's an M6 with a Moser 12, W/ 4.10's, only had about 75 miles on the rear when it dynoed.(if that matters).
No cutout or ported tb.
428rwhp and 407 rwtq.
I have since added a ported tb and went to Magnaflow cat back and will re-dyno soon.
Spellbound,
Was the over the axle portion of the pipe stock? How loud was the exhaust at idle and WOT with the ORY?
Those are good numbers!![Mr. Cool](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cool.gif)
Thanks guys!
Thanks guys!
![Cheers!!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cheers.gif)
Spellbound,
Thanks guys!
Thanks guys!
Thanks guys...
I bought a used WS6 dual outlet catback off a guy with an 01 car. It has the cutout over the intermediate pipe where it goes over the axle.
I want to have the car quieter than it is now with my dynomax ultraflo single in/out muffler but still pull decent numbers closed and open through the cutout.![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Thanks again,
Chris
Thanks again,
Chris
1 Post
Chris,
I dynoed:
361.7RWHP/464.1RWTQ w/convertor unlocked and cutout shut
376.9RWHP/480RWTQ w/convertor unlocked and cutout open
Setup in sig - stock WS6 catback with cutout right before it goes over the axle. The car is very quiet with the cutout closed - someone at the dyno was mentioning that they couldn't believe how quiet it was. I like to stay stealthy on the street.
There is more in there - I ran out of injector, so we called it quits. 30#ers are on the way, then we will go back to the dyno. Might get one pull with convertor locked to see the difference (don't know if I want to risk damage though).
More importantly, want to see what the track times look like!
I dynoed:
I dynoed yesterday with only a lid, filter, G2 MAF, and bellows and pulled a 349.2/363.1 actual....SAE corrected was 332.8/343.4. I plan on keeping the stock cat-back, and running LT's, ORY and a cutout. I'll keep you guys posted.
Beware... this will be LOUD even going through the cat-back... way louder than anything you could achieve with any cat-back alone. I shudder to think how loud that will be with a cut-out. I have it going through the cat-back - no cut-out - and I love it. But I was SHOCKED at the loudness when I first fired her up and took her for a spin.
By the way, I have pretty much the same mods as you right with the addition of the headers, ORY, and Corsa cat-back. I saw 345 rwhp and 360 rwtq SAE corrected.
