turbotech T76, built engine, 10psi pump gas
wow were did this section come from, guess PSJ had it put in for his dynoqueenness...
anyways i was running through a cutout in the back, ls1 intake, 10psi, 94 octane on the mustang dyno at detroit speedworks.
built 348 9.0:1 CR, 224/224-114 .561 comp cam, 6.0 home ported heads, cometic gaskets
all the rest of the info is on my webpage in the sig.
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
![](http://www.cofba.org/users/smokinhawk/TurboBeast-pics/dyno2.jpg)
You still on the stock TTI intercooler hawk?
I made about 480 on 6psi with the 2.5" downpipe, built engine with low compression, a small cam, LS1 intake, and through full exhaust.
Originally Posted by smokinHawk
ls1 intake maybe?
it does pull hard after 5700 now.
oh and yes im still on the stock TTi IC, but not for long![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
you'll make alot more power switching to a 3" DP and boosting into the turbo's efficency range
i hope to be boosting 13psi or more this summer.
![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
Just thinking you have more power there with tuning. Or maybe my cam is just that good
