Lowest dyno bolt-on car
but after i added a TR224 cam only.......323hp, 327tq,
Patriot 5.3 heads, Pacestter LT, LS6 intake, dyno tune.....398hp 388tq
all runs through open cut out, with 17x11 chrome ZR1's 315tires
LS6 intake #2 Maf #3 get the egr crap off/edited out ---woke my car up hard core
my car is a A4 and now with a 554/575@112 cam it dynos over 400 on 26lb injectors
so i think -a good edit and feed it some more air -youll see some nice gains -dyno without a A/C belt on i've seen some compressors really drag down a motor "due to high miles" every car has its nitch --you just need to find it --my car used to run 13.6's @103 after lid/cutout/3200 verter/12.8/after ls6 intake/maf/cam/edit 11.97@114 now mind you this is on a 2:73 gear --i now have 4:10's it will drop my ET by .04 or better
And what did all of this really do "Give me more air" if you think about it
just keep hitting the tech forum you are bound to find a lot more people that have the same issues and more that have figured out what the problem is
I have similar results with all the bolt ons and a 224/224 581/581 112 with tuning I am only able to 360hp this is through a 12 bolt with stock cat back and still the 99 ls1 intake. My best quarter was a 12.76 with terrible driving I have been working on my driving and will hopefully get it down to a low 12 second car. I have installed a cut out and plan on getting a pair of stage II 5.3 patriot heads an LS6 intake, retune and put the car on a diet. Don't feel bad about the numbers as some cars react to bolt ons differently then others. Good Luck Jessie
Lid,Mas,Corsa,SLP headsers,y,cats I had 330 rwhp, TQ i forget, AFTER i added LS6 intake I had about about 340 rwhp. The 01 and 02 have LS6 and dyno 10 or more higher.
with different exhaust/ cam set ups and i set my expectations for 450 rwhp and i get less i will disappointed. There are a lot of people out there with average dyno numbers,they just don't post.
BTW- 97 C5 307rwhp/325ftlb (intake only)--95k at dyno time.
98,200 on it now.
-Corey
