Thunder Racing TRx v.2 cam/stock heads - 451rwhp/408rwtq!
#82
Sweet, how bout some prices? Release date yet? That is a huge cam
How well do you think this cam will work on a 00' LT's, full 3" exhaust dumped before the rear, 28 lb injectors, ported TB, free mods, lid, 4.10's, asp, double roller tc and a LS1 intake unless someone has a LS6 sitting around? What kind of package are you all going to have? I have everything for the install execpt the cam, springs, retainers, keepers, and the rods. Shoot me some info, I'm ready to buy
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
![Hail](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_hail.gif)
![Driving](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_driving3.gif)
#83
I can shift faster than you.
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
All the info is posted here:
https://ls1tech.com/forums/generation-iii-internal-engine/139004-information-regarding-thunder-racing-t-rex-camshaft.html
Let me know if you have any questions!
#84
Originally Posted by Steve01SS
DAMN! What cam is that?
Yeah that car did idle like crap, but it is my first dealings with a BIG cammed car. After the last session of editing it idles a deal better I beleive. Have to ask Tim, I did it Superbowl sunday in a few hours before kickoff, so I was hurried
Just when you all think it was safe to go with the G5X2 for mo powa
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
Good job thunder!
I didnt knwo we could get away with that much duration.... Sounds like time to try a different lobe
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
#85
I cant beleive there are actually doubters that you can make this much power!
We did it in a no name shop a few months ago (thanks to Joe O), and with the knowledge at Thunder, they bested us by 30 hp a few months later. Not hard to swallow at all. Our setup peaked 419 rwhp at 6200, and theirs at 6500. Leave the intake valve open longer, and shut it later.
Car comes on like a turbo car at 4500 rpm I bet with those 3.42s
Hey jason, id like to know what the V1 specs are. My guess is (well im very sure it was on a 110 also) same LSA, but intake valve closed a few degrees earlier. Was the intake lobe larger in V2 cam with the 2 degrees advance to maintain midrange torque curve? Something like 238 or 240 intake/246 ex on a 110 straight up, or am I way off?
#89
![Question](https://ls1tech.com/forums/images/icons/icon5.gif)
Originally Posted by Jason99T/A
Just an update from today:
We installed the FAST LSx intake this afternoon. We ran out of injector in the process, so SVO 30lbs were installed. With a little tweaking, we were able to get 455rwhp/410rwtq. There is some more left with a bigger TB, some other tuning,etc., but we ran out of time to mess with today.
The intake wasn't worth alot of peak hp, but in some spots it was worth 10hp/tq in the low/mid-range.
I"ll have the dyno graphs, sound clips, and much more info on these cams later.
Jason
Jason
https://ls1tech.com/forums/showpost....3&postcount=34
That doesn't make any sense.
![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
#90
I will post up as a third party to actually seeing this car in person myself. I went to thunder ( 4 hour drive) to dyno my car and Jasons car was still on the dyno yesterday and all I have got to say is Thunder has a very nice setup with this car. Idles great and man this cam hits so amazingly hard you would not beleave how good it sounds. Geoff was awesome to deal with and thunder is in my book a class act company. The cam is simple awesome and Im sure you will sell a ton of them. Honestly after seeing this setup im thinking of doing a Ls1 setup simular with my white 99TA.
#92
Good heads usually add 40 hp anyway. Sure they are a bottleneck, but they are a bottleneck at 350 hp and 450 hp. To a point, Al Cordas car has "similair" heads. less head... more cam. Im sure this is a smaller cam than Al runs. However slight an amount ![Icon Lol](https://ls1tech.com/forums/images/smilies2/icon_lol.gif)
What I really want to know is what exhaust lobe was in V.1 of this cam, its the First traditional split marketed by Thunder
#93
Originally Posted by SMOKIN01TA
ok so at least 50 then
btw, anyone know howmany engines out there put down over 500rwhp with just a cam and stg 2 heads on a stock bottom end?
Jason, that stock bottom ends days will be numbered with heads, 90mm intake and you behind the wheel, thats more that you made with the forged 346 solid roller![EEK !!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_eek2.gif)
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
Could you be up jason's *** anymore?
![Leghump](https://ls1tech.com/forums/images/smilies/LS1Tech/leghump.gif)
Everytime someone ask a question regarding this cam or anything about thunder you chime in everytime. do u even work at thunder? i think its jason's or thunders place to answer questions about the cam or anything regarding there buisness not yours. i saw earlier you were giving spring advice and u didnt even know about the cam. i mean give it a rest already!
![MAD](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_mad.gif)
#94
well since he is twice as bussy as me and i havent said any false info yet, so what is your problem, i was very aware of what was going on thank you. also i new the cam would to have dual springs because i knew how big it was. i was just being helpful so
but fine ill shut up now if yall are going to get on my case about it.
![STFU](https://ls1tech.com/forums/images/smilies2/STFU.gif)
![Flipbird](https://ls1tech.com/forums/images/smilies2/flipbird.gif)
#95
well since he is twice as bussy as me and i havent said any false info yet, so what is your problem, i was very aware of what was going on thank you. i was just being helpful so
but fine ill shut up now if yall are going to get on my case about it. ![Flipbird](https://ls1tech.com/forums/images/smilies2/flipbird.gif)
![Huh](https://ls1tech.com/forums/images/smilies/LS1Tech/huh.gif)
apparently u suck at assumptions ED since i see jason is on here all the time. i'd rather get my info from the source than from someone who has second hand knowledge
#97
Originally Posted by wannabels1
Could you be up jason's *** anymore? ![Leghump](https://ls1tech.com/forums/images/smilies/LS1Tech/leghump.gif)
Everytime someone ask a question regarding this cam or anything about thunder you chime in everytime. do u even work at thunder? i think its jason's or thunders place to answer questions about the cam or anything regarding there buisness not yours. i saw earlier you were giving spring advice and u didnt even know about the cam. i mean give it a rest already!![MAD](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_mad.gif)
Keep posting your input smokin01ta !
#98
STF veteran / 10 second club
Whoa .... Where did the attitude come from mr 3 posts?
How about this douchebag ...
![Gay!!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_rainbow.gif)
I have tried my best to get all of the emails/PMs answered. I'll try to reply to the rest of them first thing in the morning. This is all I have been doing for the past 2 hours. lol
Get a life and STFU or get the hell off the board.
![Rolleyes](https://ls1tech.com/forums/images/smilies/LS1Tech/rolleyes.gif)
Smokin .... keep us informed on whatever you learn, and don't worry about that little boy whose giving you a hard time .... he can be easily dealt with if need be.
![Buttkick](https://ls1tech.com/forums/images/smilies2/buttkick.gif)
#99
Originally Posted by RMB
No one asked Mr 2 posts for his opinion did they ? NO ! Mr2 unless you have somthing positive or informative to speak about STFU ! IF ITS ADMIRATION YOUR AFTER PULL THE LOG OUT OF YOUR OWN *** !
#100
thanks, i want to know what this young fool drives so i can make sure i toast his *** next time i see him around
And why are people asking for an A4 cam? Why wouldn't this cam work in an A4? I think it would fine.
