522rwhp 440rwtq!!! A4, 346, ;) UPDATE Track Results, In Car Vid 4/10/11
#45
the valves were really nice, my exhaust valves 1.575 are now heavier than my intakes...If i were to get TFS heads or anything with a 2.04" valve and larger these are a no brainer...almost the weight of Ti and 1/4 the cost...
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
mine will see most likely 7300ish...i have a shift extension of 1300 and 1200
#54
The cam that was in the car was a Futral Grind spec'd for a friends 383. When he upgraded to a 408 and a cam by Geoff, I got his old 383 cam and threw it in my Nova since it was a lot lighter and a Race car. That was a 239/243 .612/.612 112lsa+2. The car ran faster the higher i shifted it even with the old.6.0 truck intake.
The cam Geoff spec'd me is a 238/250 .603/.596 110lsa+4. THis should put me shifting at 7000 now instead of having to rev so high. I was running old stock lifters and bought a new set of ls7 lifters. as it was spur of the moment finding out they were bad.
Motor is in the car now but I have to finish putting intake, headers , water pump etc on and getting it running. Will dyno it sometime maybe next week or atleast run it at the track next week if weather permits.
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
Old cam went 10.24@128 with a 1.42 60 ft. Pulled the plugs and were coated with oil since the rings never seated the first go around. If the rings seat properly this go around it should have quite a bit more cyl psi. 9's or bust
#56
Holly crap lol. So are you running a stock ls1 or a ls2??? Because geoff spaced me that same cam but a 238/ 608 252/596 on a 111+3 for my ls1 setup with the same goals in mind nines
#58
yeah if i do a 347 over winter i will bump the compression with lightweight slugs, e85, let it spin it the moon with a larger cam, go solid roller, and light tension rings with a well balanced setup)...we will see though, i am getting ahead of myself...hahaha
pretty good setup though on the 5.3 heads...60ft could use some work...you should get 9s in just the 60ft alone...
I need to get a 2500lb fox roller and see what this thing can really do
#59
My other cam was all wrong for my engine, this cam was built with 60 ft in mind as it will build a lot more cyl pressure.
With the other cam, I could have ran it on 87 octane if I wanted with 11.64/1 compression
Yes it was 2600 with me in it last time I scaled it. That was 30 lbs ago on my own body weight.
