What cam would put down numbers like this?
https://ls1tech.com/forums/multimedi...ound-like.html
I just got the car dynoed today. First run is cutout closed, 2nd is open. I have no idea if headwork was done or not.
Numbers are hard to read... closed is 364.59 HP 365.10 TQ. open is 370.94 HP 367.73 TQ
Warning ricer math ahead: Figure it likely picks up at least 10-15rwhp with a ls6 intake (and revs better) and minimum 5-10rwhp with longtubes and he is right there ~385+rwhp.
Pretty typical for a small cam ls1 on a dyno that isn't overly optimistic.
If you don't have a good tune the numbers are even better for what you have. Don't swap cams until you optimize intake/exhaust.
ls6 or better intake, cheap longtubes, and a tune should put you within the range of 400hp and the car will drive like stock...good setup to me
Also the running rich issue when I had it dynoed was due to me putting a stock MAF on it. I bought the car with a SLP 85mm and noticed the car would spark knock. I thought it was the big MAF causing it because I had no clue any of this was done. And I found out the guy had the car dyno tuned WITH the 85mm MAF. The crappy plug and wire change that the guy I bought it from was causing the spark knock.
The car originally dynoed 380hp 379tq. So I think by me putting the 85mm maf back on it should be back up to the numbers it originally put down.
Speed INc. dyno tuned it back then.
I thank him for creating such a quiet, mild-mannered combo that drives like stock and runs phenomenal!
