TH400 low dyno numbers
I know n/a numbers don't really matter if in the end it's going to have the bottle on it, but I was just wondering if any of you other th400 guys have ever dynoed your cars and seen numbers as low as mine. 100 horsepower seems like a lot to be leaving on the table. First pull was 322, so I guess on the positive side I did pick up 15hp.
What i think happens on these load dynos is that they push the converter way out of its efficiency range. I know when i was on the dyno it took far longer to wind out third gear then it would have on the street.
Another example same day there was a 68 camaro with a 468 (not really all that built) put down only 344 rwhp and ran 7.30 at 94 in the 1/8th, he had a 4400 stall.
https://ls1tech.com/forums/drag-raci...g-outcome.html
I did run an 11.5@118 two weeks ago when the tune was still half ***. I would think now it's a few tenths quicker, but I won't be able to know for sure for at least another month or so when I get time to make another trip to the track. Plus I'm curious to see How much the car will pick up on spray
