Low Dyno #'s, running rich?
Basically, can someone tell me what is going on? Are Mustang Dynos known to dyno higher? Is between 11-12 a rich A/F that would cause me to loose 20rwhp? What does the spikeyness mean? Please help! I am fine if my car is actually only making 304.7rwhp, I just want to know what it is actually making!
Here is my dyno chart...any suggestions would be great!
Now...am I really running rich? And what about the little spikes throughout the curve?
Oh well, this will just make me want to make it faster!
Oh well, this will just make me want to make it faster!I just re-read your first post and you said your first dyno was with the cutout open. Was your highest dyno on Mike's machine with the cutout open as well? If it wasent then I would say thats some of your missing hp right there. GMMG is a high flowing cat back but the cutout should still produce better gains in comparison. I gained 15hp and 15 tq throughout the curve with mine Open FWIW.
What are your plans for the next mod to the engine? That may help you decide what to do about your problem as far as time and cost effeciency goes.
Yeah, what he said. I tryed to get my last post in before you, JRP. But you too quick.
Revelation,
I don't know what I want to do next performance wise. I still need to worry about warranty and may be purchasing an extended warranty because this car is my DD. Plus I don't have enough money right now to do anything major. Suggestions would be welcome, but I don't know what I can do for under like $200.
Again, I'm not too worried about it because I know how many variables play into it, espically with dramatically different weather between the 2 times and using two different machines. She still pulls like hell and beats anything out there. I really need to take it to the track and see what is going on there!
KR or Knock Retard is caused by vibrations in the engine block and detonation. In the event either of these are detected by a knock sensor and a signal is sent to the PCM and the PCM will reduce timing to protect the engine.
Detonation occurs when the air/fuel mixture is compressed and the temperature goes up. The more compression, the higher the temp. At some point, the fuel may spontaneously ignite prior to the spark plug firing. This is detonation and it is very bad for an engine because it often occurs just before the plug fires. You then end up with two flame fronts in the cylinder that crash into each other which can crack pistons and rings, etc.6
Octane is a measure of how much a given blend of fuel resists detonation.
taken from install U
Seriously though, I think you could try the ported MAF ends till you get some big cash. Hell, if they dont work just send em back.
There is also SSRA and the Underdrive Pulley (I dont think GM would have a problem with those) Or if that 200 is burning a hole in your pocket you could go for some more suspention stuff (LCA's, PHB, etc.) Since you dont want to void the warranty, maybe you could get the Hot Cam or some other small cam that they wouldnt notice when you save up a little.
Once the weather clears up a bit I would love to head out to the track! The problem is, if it is really crowded and I only get a few passes, it won't really feel worth it because I am sure I will screw most of them up having NEVER raced before and this being my first M6 car! But hey, practice makes perfect. Maybe in a month or two I'll use my mod money to pick up a helmet or that SSRA.
Anyhoots, thanks for all the thoughts and opinions! We need to hang out again soon. This coming weekend I will be gone skiing (the other reason I have no mod money right now!) but the sunday after that, March 7th, we should try to arrange another get together out in Woodland Hills! Catch ya laters.
Yea, snow season has eaten up some of my modding funds as well. Im heading up to to Bear again this Friday, should be some nice powder left. The weatherman said they got 9" since yesterday. SCWEEET
Dynojet gives higher numbers don't they?
