TSM Tuned H/C/I M6 thru 12-Bolt - 479/425
So the car was running a bit off, so I took it to True Street and had them run it on the Dyno with WB plugged in - it turned out to be running extremely rich (10.2-10.8). Sean worked his magic, and with the EQ, MAF and VE all in check, I walked away happy. Guy knows his stuf....
Motor
Stock Bottom End LS1 - 60,000 miles
Fast 90mm Intake
Nick Williams 90mm Throttle Body
PRC Stage 2.5 5.3L heads
Comp Cam 238/242 .605/.610 115+5
PRC Dual Springs
SVO 42# Injectors
Walbro 255lph Pump
1 7/8 Kooks Race Headers
TSP Off-road Y
TSP 3" Cutout
Corsa Catback
Motor
Fast 90mm Intake
PRC Dual Springs
SVO 42# Injectors
Walbro 255lph Pump
TSP Off-road Y
TSP 3" Cutout
Corsa Catback
Those #'s are STD, so for apples/apples comparison sake you'd probably made 455'ish if the #'s were corrected/SAE. Still a stout setup especially through a 12 bolt which robs about 20hp.
Thanks - I eventually will be looking to port the FAST and I'm thinking about re-doing the exhaust to find some more power (True Duals or maybe a 4" merge) as well as doing a UDP and a EWP but haven't decided if I want to go that route.
