Does this sound about right for power?
Old Aug 5, 2011 | 08:29 AM
ripgtp97's Avatar
Question Does this sound about right for power?
2000 Trans am A4
When I first dynoed the car all it had on was a borla-non adjustable catback. With a misfiring issue do to a cam sensor.
car made: 280 hp 290 tq
Now it has 1 3/4 long tubes, ORY, LM2 catback, Lid/k&n, P&P TB, ls6 intake, and a tune
it made 335hp and 340tq
So it looks like it gained 55 hp and 50 tq
Does all of that add up to be about right for what went into it and is it safe to say my car is somewhat of a "dud" with a low baseline
Old Aug 5, 2011 | 08:43 AM
410strokerss's Avatar
Originally Posted by ripgtp97
2000 Trans am A4
the sensor problem surely hurt ya and retarded your timing for sure..
Old Aug 5, 2011 | 08:47 AM
ripgtp97's Avatar
yeah for sure, with that fixed though, assuming the power would go back up to around 300 stock, shouldn't I be seeing higher numbers with everything added and the timing fixed?
Old Aug 5, 2011 | 10:23 AM
LeanPocket's Avatar
yes its close to where it should be, but it should be a lil higher
Old Aug 5, 2011 | 10:29 AM
LeanPocket's Avatar
might sound stupid but uh, how does ur fuel filter look? Air filter? Plugs? Oil? Proper Gasoline Octane? Trans fluid? might be bogging it down
Old Aug 5, 2011 | 10:33 AM
ripgtp97's Avatar
Filter is like new, just installed tr 55 plugs with ngk wires, oil is actually due for a change, 93 octane. haven't checked the fuel filter
just a little bummed with the work into it, its only at 335
Old Aug 5, 2011 | 01:17 PM
idle's Avatar
I'd figure you'd be about 340ish at least... just sayin'.
Old Aug 5, 2011 | 02:01 PM
ds98formula's Avatar
I would say it's not too low. It is a auto. Underdrive pulley and stall and run mid12's easy
Old Aug 5, 2011 | 02:45 PM
BAMALS1's Avatar
I say that's really good for the mods...my car made 290/289 with a lid, catback, underdrive pulley, ls1intake, CAI, and 3600 converter.
314/314 after header install and Y
My best e.t. is 12.47 @109 with 2.73's
Old Aug 5, 2011 | 03:39 PM
ripgtp97's Avatar
ah i see, yeah the tuner said he's seen variations anywhere from 30 hp less to even 30hp more than where I'm at so it really depends on the car
this was on a mustang dyno too, so probably more realistic than a dynojet so ive heard
either way i'm taking it to the track in a couple of weeks, excited to see what it puts down
Old Aug 5, 2011 | 04:17 PM
Johnnystock's Avatar
Sounds realistic for an auto on a mustang. Dont forget its internet; everyone has a better rwhp than you and me..
Old Aug 5, 2011 | 11:28 PM
BAMALS1's Avatar
I dont think its a dud, might suprise you.
Old Aug 6, 2011 | 08:36 PM
67RSCamaroVette's Avatar
was it a mail order tune or a dynotune?
Old Aug 7, 2011 | 11:27 AM
ripgtp97's Avatar
dynotune, on a mustang dyno
Old Aug 7, 2011 | 11:43 AM
dirkdiggler350's Avatar
Those numbers are right on for what you have done, I put down 330/330 with pretty much same mods on his dyno. Put a stall in it and it will be a different car. Don did a yank 3600 in my car and it was best mod I've done so far.
Old Aug 7, 2011 | 01:38 PM
kinglt-1's Avatar
It's a A4, those numbers are solid.
Old Aug 7, 2011 | 02:03 PM
BAMALS1's Avatar
Like everyone has said strong numbers for sure...don't be dissapointed...see what it puts down at the track
Old Aug 7, 2011 | 02:15 PM
T.Man's Avatar
Numbers look good with regard to a loaded dyno and being an A4. Have fun with her OP!
Old Aug 7, 2011 | 02:52 PM
s346k's Avatar
well, the dyno did show a positive gain from the mods. as long as it traps 109+ i'd be happy with it.
Old Aug 7, 2011 | 06:10 PM
ripgtp97's Avatar
well this all sounds reassuring, thanks guys!
and dirkdiggler, I can't wait to stall it. That's next at the same time as my gears
