Dont seem to be getting power out of the car
Old Aug 9, 2011 | 01:00 AM
1998MysticZ28's Avatar
Default Dont seem to be getting power out of the car
Finally got my car tuned. I really like driving this car drives really great on the road. Found a couple problems with the setup though when on the dyno.
Made 350/317 on a mustang dyno.
Specs
347 Ls1
PRC ported LS6 Heads
232/236 114 lsa cam
LS6 Intake and ported TB
42" injectors
3600 stall speed
4.10 gears (Big Problem)
What do you guys think
Old Aug 9, 2011 | 07:00 AM
Just seems like my car is not as fast as some of the cars on this site, with the same set up
Old Aug 9, 2011 | 07:55 AM
c0ncEpT's Avatar
Make a pass and report back with results.
Friend of mine made 360RWHP on a mustang dyno and ran 11.6x @ 117.
That was through an auto @ 3700lbs.
Dyno numbers don't mean chit!
Old Aug 9, 2011 | 08:02 AM
Yeah I know they dont mean ****, Im going to the track Wednesday night to see. Just doing some mock runs on the street it felt like it pulled harder with a taller gear
Old Aug 9, 2011 | 08:19 AM
MikeG's Avatar
Unlocked converter?
Old Aug 9, 2011 | 08:23 AM
9.5 billet with a lock up but was unlocked during runs
Old Aug 9, 2011 | 09:37 AM
thunderstruck507's Avatar
Unlocked converter and the pull ended before HP peaked.
My car made a whopping 345rwhp on a dynojet through an unlocked converter with the mods in my sig (headers, cam, full exhaust, fast90/90). At the track it seems to be doing decent though.
But report back with trap speeds just in case there is an issue.
Old Aug 9, 2011 | 03:38 PM
blk/slvr02ss's Avatar
What did u do different to the car since the last time @ the track ?No track this week w/ all this rain !
Old Aug 9, 2011 | 06:28 PM
Sofls1's Avatar
Specs
347 Ls1
232/236 114 lsa cam
42" injectors
3600 stall speed
Like someone else in the thread stated, the numbers really don't make any difference. Track times and trap speed will give you a real indicator of whats going on. If you go to the track, and get disappointing results, then you have a problem.
Old Aug 9, 2011 | 06:49 PM
Yes Dyno #'s mean nothing My 02 Camaro SS made 325 rwhp and u seen that car run !
Old Aug 9, 2011 | 07:46 PM
Slowhawk's Avatar
LS1Tech Sponsor
Thats why the #'s are low.
Old Aug 9, 2011 | 10:03 PM
explain slowhawk
Old Aug 10, 2011 | 08:40 AM
MikeG's Avatar
Having the converter unlocked causes more power loss through the drivetrain.
If the pull was made to 6700 RPM or so with the converter locked, it probably would have hit 380ish.
Old Aug 11, 2011 | 09:01 AM
okay that makes sense, went to the track last night and best run was 12.3 at 111 spinning at the line and hitting the limiter on 2-3 shift
Old Aug 11, 2011 | 10:59 AM
What was the DA?
You can calculate here: http://www.dragtimes.com/da-density-...calculator.php
If the DA was pretty bad, I would say you are in the ballpark. My car did 111mph but in 1840 DA. I likely weigh a couple hundred lbs over you. When the DA got REAL bad (over 3000+) I slowed to ~107-108.
Old Aug 11, 2011 | 11:32 AM
Density Altitude: 1721 feet
Relative Density: 95.06 %
It was warm out there, It rained all day there so there was no prep or very little, so I think thats why Im spinning at the line, and just got to time my 1-2 shift better. All in all I was happy just re learning the car last night
Old Aug 14, 2011 | 11:57 PM
NVR_SPDS's Avatar
Are you manually shifting? Also, maybe i missed it, but what do you have for exhaust?
Unlocked numbers are definitly going to be lower than locked, but locked numbers dont mean anything unless your running a converter that can handle locking up under WOT conditions.
