2009 Z06 + ECS Blower
http://www.youtube.com/watch?v=zOv68...1&feature=plcp
That car at the track with a new driver goes 127-128mph very easily. Its got 129/130mph in it with a seasoned driver. With that being said there is more left in the tuneup on the Z06.
Winterblend(10-15% ethanol) fuel kills 3-5 degrees of timing
Stock exhaust
7.1# of boost tied to 8 degrees of timing due to the fuel
Your tuner will tell you that most of these setups will end up at 14-15 degrees of timing at 8psi. Not making excuses just stating the facts. The exhaust is probably worth 10-15rwhp and the timing is probably worth 20-25rwhp
525 + 70rwhp dyno difference + 15(exhaust) + 25 fuel/timing, gets you right around 630 on a dynojet.
Anywho, congrats!!
Not sure if you will really be able to pump up 5* of timing just with summer gas, unless the car was tuned on 91 and summer it will be on 93 octane.
2nd, sounds like the car was tuned off the stock KR settings. The E-38's in the Vette's WILL pick up alot of false KR from the blower belt setup. It just has to be adjusted. I will run 12-14 degree's at that boost level and the 427ci picks up 160-180rwhp ussually.
Atleast it's safe for now.
) lol
