224/233 cam only results
Adding 224/233 .568 .578 115ls cam with 918 springs, and a quick E-Tune, it
did 398rwhp@6500rpm and 365rwtq@5000rpm.
All in all a 55rwhp gain, with decent high RPM power (stays flat to around 6900rpm). It should work well with the blower too..
Idle is decent @ 900rpm, and it never makes less power than the stock cam. I leaked it down twice and comp tested it twice at MY SHOP..
Its came back less than 2% in EVERY HOLE and 225PSI in EVERY HOLE...
I'm gonna run the car real soon once i get my shift points set and then play with cam timing and then possible a few other changes
JS
, whats the under the curve power look like though.
