Heintz Racing Built Stock Bottom End LS7 makes 620 RWHP NA!
Closed ex-Sponsor Account
This particular car would happen to be our shop car that we tinker and try different setups on. If you remember a few years back, this is the car that made 560 RWHP with a LS2 402, but we decided that it was a little too radical. https://ls1tech.com/forums/dynamomet...p-504rwtq.html This setup with the LS7 drives so much better and pulls so much harder than the last. Figured I would share the results with you guys, as I think the car turned out great.
2005 C6 M6 Corvette
Dry Sump
Callaway Honker CAI
Advanced Induction Ported Stock LS7 Heads 13:1 Compression Ratio
Advanced Induction Ported Stock LS7 Manifold with 102mm Opening and NW102mm TB
Heintz Racing/Advanced Induction Custom Camshaft
Stock Rockers with Comp Trunion Upgrade
Meziere EWP
Kooks 1 7/8 Stepped to 2" LS7 Headers
Off Road 3" X-Pipe
Magnaflow 3" Catback
Stock Balancer (No UDP)
Spec 4+ Single Disc Clutch
3.42 Gear
Pump Gas 93!
TR6 Plugs
Heintz Racing SD Tuned with HPT
Here is the dyno graph, I believe it speaks for its self.
Enjoy!
Zach
2005 C6 M6 Corvette
Dry Sump
Callaway Honker CAI
Meziere EWP
Off Road 3" X-Pipe
3.42 Gear
Pump Gas 93!
TR6 Plugs
Enjoy!
Zach
No fly cutting, but its tight. I would not want to go any tighter without fly cutting.
Zach
Running the numbers, I am coming up with 9.59:1 DCR. The intake Adv Closes at 72 ABDC.
These are the numbers I am running through the calculator-
Cylinders-8
Bore-4.125
Stroke-4.000
Rod Length-6.067
SCR-13:1
Intake Valve Closes ABDC-72.0 Deg
Boost-0
Altitude-850ft
Hope that helps ya!
Zach
Cylinders-8
Bore-4.125
Stroke-4.000
Rod Length-6.067
SCR-13:1
Boost-0
Altitude-850ft
Hope that helps ya!
Zach
I will check it on my calculator. I figured you would have to run a wider lobe sep to get a cam that big to clear the stock pistons and get the DCR in the 8.8 range. I have found that anything over 9 DCR on 93 around here won't take much timing. 8.8 seems to be the sweet spot. You got more guts than I do. 110 lobe sep and carying power up that high is awsome. I guess GM sunk the valves a little deeper in the LS7 heads than the LS3's. Great work.
What do you think a FAST 102 ported by AI and an UD pulley would get you? Are there any future plans to do something like that? I plan on doing a 440-454ci combo in the future to demolish my 416 but I am looking to get near 700rw. Probably going to need to go sheet metal and solid roller but I would like to see the plastic manifolds and HR cams pushed to their limits before I commit. You all seem to be heading in that direction.
It pulls very hard on the street. A NA motor making this kind of power feels to me like an 750-800rwhp blower car.
This is Jeffs car, the owner of the shop.
Zach
I love it when a shop does a smart build and defies the conventional forum wisdom (in this case the need for a fast 102 LXR intake va ported stock ls7 mani, or the UDP that is usually included without thought)
This is a very sharp, inspirational build that makes more power than many of the 440-454ci setups I'm seeing.
Sent you an email, Zach. Please let me know your thoughts!
Thanks for sharing the latest on Nick's old C5.
Wonder what he charged himself for a NW 102 TB... ;-)
