dyno results seem wack!
Old Sep 30, 2012 | 08:46 PM
hotrodth's Avatar
Default dyno results seem wack!
Put down 350whp na. Stock bottom end. Mods in sig. With 150 dry shot it made 544. Any ideas why so low na. Should easly b 450.
Old Sep 30, 2012 | 09:35 PM
clonedws6's Avatar
Run it. Dynos are wack
Old Sep 30, 2012 | 09:59 PM
MeMz's Avatar
What exhaust setup?
Old Sep 30, 2012 | 10:12 PM
LQ4-K5's Avatar
Its all in the tuning, maybe the setup just favors the spray. Has it ever been on the dyno before (anything to compare to) or was this the first time? Usually if a dyno is off its off across the board. In other words your runs would be consistent with one another but not accurate to what the car is truly doing. Rarely do they turn out erratic numbers from one run to the next. So, your 2 numbers may be off, but they are off proportionally to one another. Obviously I wasn't there when you ran your car, just letting you know what I've learned.
Old Oct 1, 2012 | 06:13 AM
hotrodth's Avatar
Was on dyno when I first put the motor in my truck. It was 100% bone stock. Now ls6 intake 233/239 cam top 2.5 5.3 heads. Stock I put down 312 w auto. Now Im m6 also. I should b 430-450whp easy. Have lts w 3" dual x pipe and magnaflow muffler.
Old Oct 1, 2012 | 06:14 AM
hotrodth's Avatar
Afr on na pull was 12.9-13.0 timing at 27° and n2o was 11.2-11.4 not sure timing
Old Oct 1, 2012 | 06:57 AM
Blackbird-WS6's Avatar
Who tuned your car??
Old Oct 1, 2012 | 07:19 AM
hotrodth's Avatar
Is name is tony screen name is hardcore on here. Has yellow gto that runs 9s. We only have street tuned it. Was dyno day yesterday. So just wanted to see numbers. Wasn't happy.
Old Oct 1, 2012 | 07:23 AM
screaminz847's Avatar
Did you degree the cam? If not, it could almost be a tooth off. I remember back in the TL1 days, a guy put a GM847 cam in his and ran 101 in the 1/4. He was pissed, took it apart and found it was a tooth off - corrected it and went 115, so sometimes its not noticeable - he even said the idle wasn't very different before and after.
Since you seem to have a decent tuner, I'd check the mechanical items first.
Old Oct 1, 2012 | 08:10 AM
hotrodth's Avatar
No didn't degree it. That will suck if that's the case....
Old Oct 1, 2012 | 09:01 AM
Slowhawk's Avatar
LS1Tech Sponsor
They could of dyno'd it in 3rd for the NA pull?
Old Oct 1, 2012 | 10:55 AM
hotrodth's Avatar
I did the dyno pulls. All were in 4th. Also think if it was to do a pull in 3rd it would read higher.
Old Oct 1, 2012 | 11:03 AM
LQ4-K5's Avatar
Originally Posted by hotrodth
Is name is tony screen name is hardcore on here. Has yellow gto that runs 9s. We only have street tuned it. Was dyno day yesterday...
I would PM him and see what he thinks.
Old Oct 1, 2012 | 11:54 AM
What kind of dyno?? Dynojet or mustang
Old Oct 1, 2012 | 11:59 AM
hotrodth's Avatar
Was a dyno jet. Also my tuner was there with me. The place didn't allow any tuning.
Old Oct 1, 2012 | 12:04 PM
What i dont get is lets say you do make 450whp, why did you only gain 95whp with 150shot?? So either your na numbers are lower then 450 or your spray tune isnt righ...
If it was my car i would bring it to a diff well known tuner and have him look at it, better to be safe then sorry
Old Oct 1, 2012 | 01:36 PM
hotrodth's Avatar
Just looked at my pulls again. 362 motor. 544 on 150 shot...that's 182 hp gain off 150 shot. just sayin with my setup I should be 430-450 motor and 600 or better on spray.
Old Oct 1, 2012 | 02:12 PM
that would stand true if the numbers you posted are right but thats what your questioning so thats why you should have it checked out, at the very min i dont see why your setup shouldnt make 400whp na
how many miles on the motor?? maybe have a compression test done
Old Oct 1, 2012 | 02:27 PM
hotrodth's Avatar
38k and 185-190 across the board an all cyl
Old Oct 1, 2012 | 03:30 PM
Lee12609's Avatar
what was it revved to on the dyno. where was peak, when did it fall off, etc....
alot could be learned from posting a dyno sheet.
