New Dyno numbers LSX build 563 RWHP 539 TRQ
I just dynoed my new LSX 454 motor put togethor by AES and block taken to superdeck 1 level by ERL before build on my nitrous pull I made around 723 RWHP and 730 RWTQ
Heads are trick flow 265s degreed at 45 instead of the normal 55 degree angle, 11.5 to 1 compression, used 15cc dished pistons so I would still be under 12 to 1 compression. Cam is a 260/272 on 112. Kooks longtube 3 inch true dual with electric dumps off the headers. Six speed spec twin disk clutch and ford 9 inch with 3.90 gears..... I think thats most of it and LSX 102 ported with 100 mm maf and the 104 Fast toys.... I talked with Mike at TEA and he is still thinking the numbers are low for a 454 solid roller built to turn 8000 rpm.... So I will be back to the pin and paper again soon but for now thats where Im sitting.
https://ls1tech.com/forums/attachmen...y-hpnx0166.jpg
I tried to attach my kooks exhaust but I had a pic in the exhaust section last year when we talked about the kooks true dual exhaust, I think the attached link will work.
It wasn't on a Mustang dyno but I will attach the dyno as soon as I can get a picture or have Bluecat send me a copy of the dyno on the internet so I will already have a copy on the pc. I think they only took it up to 6300 and where it is a solid roller I was told the motor can run up to 8 grand so I was kinda wondering about that, in a few weeks or so Im gonna try to do a few things and tweak it and send it someone that I think can find out if there is any restrictions with the setup because I feel with the setup I have it should make 600 plus at the rear wheels also.
To be honest with you I think I still have a fuel problem that needs addressed and I am going to try to make changes to it and then see where we are at because I ran the aeromotive a340 w the 99-02 bucket style sending unit and from what I know now with the fuel issues I am having to address this pump was not intended to be run in the 99-02 style fuel bucket setup and I am going to have lonnies do me a double walbro in tank sending unit and wiring harness.....
