Polluter V.2 CAM ONLY numbers inside!
what set of heads would pair best with this cam martin
I would say 400+ would be very realistic for an auto car.
It is an Extreme RPM Hi Lift exhaust lobe. I really like it on the exhaust side of things. It keeps the valve-train very stable and allows for the clean pulls you're seeing.
I also lied guys we did do some dyno pulls back in June when we installed his headers and true duals. Here are the last two pulls we made on his car then. Looks like at least a 70rwhp/35rwtq gain from the V.2 Polluter!!!!
Is this a N/A cam? or is it nitrous friendly aswell
In comparison to the v1 polluter, whats the difference between these two cams? I think the v1 (242/244 6xx/6xx 112lsa? ) put down 417 HP with budget headers and y pipe setup. What weren't you satisfied with the v1 to have it redesigned to the v2?
Is this considered a more streetable version? or more all out high revving design
Thx martin
Is this considered a more streetable version? oFor more all out high revving design
Thx martin
The main reason I changed the design was for valve train stability. Some had valve train issues with the xer lobes it was ground on. It was also extremely peaky due to its 53 intake valve close event from the 242 duration intake lobe and the cam having no advance. As you can see the torque and under the curve gains are very impressive. I will overlay the before and after graphs tomorrow. Search any of the old cam only threads or go to our website and compare under the curve power. Smaller intake lobe, earlier ivc event still makes more peak power.
What impresses me the most is the torque curve-I would not of expected that out of a 346 with that size cam.
There some guy here who posted his results with another company's cam and it was close to your .050 sizes but totally lacked torque. He could really use this cam.
That split-while it doesn't look big at .050, most folks wouldn't think of spraying it-but that exhaust lobe loves nitrous or boost.
