LS2 GTO "Cam-Only" w/ SNS Stage 2&FAST102/
Just finished up dyno tuning this nice looking 6.0 GTO. It is running one of our Saturday Night Special series "TorqueMAX" cams. This is the Stage 2 227/235 .61x"/.62x" 110+3 version. The car has minimal bolt-ons including 1x7/8" headers, 3" catted X-pipe with 3" Magnaflow exhaust and a Vararam intake. It also has a Fast 102 intake with the stock 90mm LS2 TB.
Idle clip:
Sounds very tame with the Magnaflow Mufflers and cats.
SAE:
STD:
Very nice power and torque curve for stock heads and the minimal amounts of bolt-ons the car has. Without cats I'd expect it to pick up 5-10rwhp and with a larger MAF and an under-drive pulley it could pick up another 10-15rwhp there. Lots of potential for future modifications!
Main thing is it drives very well. The 6.0 soaks up the overlap and spits it out like a purring kitten. 6th gear at 55mph is not a problem at all.
Idle clip:
SAE:
STD:
I just got more excited about our little talk the other day. May can't come soon enough. I will post up my numbers when I get them. I think we will crush my desired numbers. Great cam, wish I would have though of it. Lol. That thing is producing for sure.
It is the down low tq and past peak hp numbers that are impressing me the most. With an A4 you have to look at shift extension and shift recovery rpm since it is such a drastic drop with only two gear shifts. You could easily run this cam out to 6,800 or a little higher if need be in 1st and the flat tq curve will aid in recovery down below the 4,000 range which is where you will be after the shift. I am having to rethink my converter selection now. On most of the cams that make this much hp there is about a 25-50rwtq gain from 3,200 to 3,600 so the 3,600 stall was a no brainer and worth the loss in drivability. But this cam only gains 10rwtq from 3,200-3,600 and really only peaks another 20rwtq at 4,750. What to do, what to do.
I am thinking I may be able to hit 450rw out of the TBSS with me porting the heads and intake but my 1 3/4" headers and 2.5" catted Y will hurt some. I will have an U/D and the rest of the bolt ons though. We will see. I am loving this cam. But of course I will have to have that one degree of seperation like we discussed. I always have to be a little different.
Has the customer reported on stuff like drivability and milage yet? With those power numbers I guess milage doesn't really matter and I am sure the drivability is great considering how small the cam actually is. Just curious as to the customers impressions.
I did a similar cam and springs last fall on this GTO, easily done.
430hp 400 tq all day long.
http://s704.beta.photobucket.com/use...ml?sort=3&o=24
http://s704.beta.photobucket.com/use...tml?sort=3&o=3
The car is actually still here at the shop as we're finishing up the tune. So far all the customers with this cam aside from one that didn't really give us enough time to finish up his tune before he wanted to pick the car up love the drivability. I know you know what you're doing when it comes to tuning so you should have no issues getting it to drive nicely. I think an auto is a little more forgiving when it comes to drivability versus a M6 anyways.
I'm in no way saying that's what your numbers are, it just sounded like from your post that you were trying to say that this isn't anything special, which it isn't. What it is though is real world, and very realistic to what the average enthusiast can expect.
They are very popular right now and this 227/235 110+3 Stage 2 grind along with the 235/243 111+2 Stage 3 are probably my best selling and most popular grinds.
Thanks for the tuning Props Martin. I have been doing a lot of studying up this trip so I don't leave anything out on the next E38 tunes I do.
Now I really am second guessing the 3,600 stall. It will still be faster at the track. 11.9's@110 full weight (4,850) or bust with "stock" parts.
Thank you sir!
They both have 2's and 7's in the numbers...........
But seriously, you have a bit less duration and more lift. Kind of a irrelevant point when it comes to the power produced as they both gave similar dyno results above cruising rpm. My buddy wanted more of a choppy idle so he went with more duration and did not want to. Get into the engine and have to fly cut the piston tops so he chose less lift. My buddies GTO has the stock intake and stock throttle body. Next will be heads, intake and throttle body.
