Dynojet Vs Mustang Dyno
220/224 530/534 112, Hooker LT, 3" custom y-pipe w/ dump, port matched Weiand intake, ported stock Maf and TB, SLP lid w/ K&N, NOSzle DP (installed but not spraying), Moser 9" 3.70 w/ 35spline axle and Detroit Locker, and 26 10.5 ET Streets. (stock tune)
Last night on a Mustang Dyno the same mods as above w/ the addition of PP S2 heads and 1.85 Comp rockers. We guessed the weight at 3800#. We spent $80.00 for an hour of tuning. We started w/ 334.9 hp @ 6250rpm w/ 14.0 a/f and 313.2 tq at 5000. We changed timing and fuel through about 6 pulls and ended up with a best of 343.4 hp@ 6250 and 379.4 tq @ 3000. There is a spike on the tq, aparently I didn't roll in to it well. On the graph it looks a little more like 325-330 on the tq. We moved the torque curve from just peaking over 300, to the entire curvre being above 300.
I'm happy with the tuning, since all we worked on was spark and fuel. My question is, how do these numbers compare to the Dynojet? Is there any way to estimate gains from the Heads and Rockers? We'll be on the dynojet in June. Comparing my car w/ what others pulled that were on the dynojet last year, I'm a little dissapointed. There may be another cam change in my future. How streetable is the Grand-Am cup cam?
As far as comparing dyno numbers between one dyno and another, I say just don't do it. Even if they were both dynojet's, not all dyno's read the same.
That said, I prefer a Mustang dyno just due to the eddy current feature they have. I feel it makes it easier to get a more accurate tune. I think that most shops end up using Dynojet's due to the customer support with tuning, but I could be wrong. I believe that Dynojet is supposed to be releasing an eddy current add on for their dyno's, at some point, as well.
All that aside, your numbers sound a little on the low side to me, whether you're M6 or A4. If you're sure something isn't wrong with your car and it IS the cam holding you back, I'd recommend you look into a custom grind cam.
as far as numbers being different from one dynojet to another depends on which software they use. older dynojets, like the one used at www.vincihighperformance.com uses the Society of Automotive Engineers (SAF) standard J1349 Rev JUN90. Correcting to SAE J1349 alters the data to make it seem as if it was taken when the atmospheric pressure was 29.23 in/hg., the temperature 77°F and the humidity zero.
the newer dynojets use the "standard corrected," popular with aftermarket manufacturers (no doubt because it uses 29.92 in/hg and 68°F' to get bigger numbers).
all this right off dynojet's site here: http://dynojet.com/gmhtpmag3.shtml from an atricle that GMHTP did on the dynjet.
so, what does this tell you? numbers are just that. numbers. the wife's 99 formy makes 316.7 rwhp and 329.6 rwtq on vinci's dyno using the older specs. http://www.stealthram.com/familypics/formula/dyno59.jpg now i can go to a newer dynojet and use the "standard correction" and get the higher numbers you guys are getting. but why? just so i can say look at my higher numbers? i'd rather keep my lower numbers because they are more true to the original numbers when doing the math.
one of the SS camaros vinci did put up 266 rwhp completely stock. now doing the 20% math brings it 332 hp. pretty close to the 327 factory rating. http://www.vincihighperformance.com/...s/ls1_zult.gif this graph off of their ultimate package on the fbody page here: http://www.vincihighperformance.com/fbodyls1.html then click ultimate at bottom left.
the thing to do is whatever dyno you started on, stay on. it's the only way you'll get accurate results on changes made.
One of the local dyno shops opted for a Dynojet along with the eddy current add on, but from what I gather the eddy current add on isn't being released yet.Funny that you mention the SS at Vinci though, my car is pictured on his site (photo taken before it was mine).
Moral of the story, don't rush an install to get to a dyno.
In May, we're going to get about 2 hrs of dyno tune time and max this puppy out.
Mustang vs D-jet
Impress people who don't know any better w/ a d-jet.
Tune "your" car on a Mustang, just make sure the weight and range is right. I went from 60 to 120 and the 6300 shift light was right at 120. My car is an M6.
On a seperate note, one of our local club guys has an Impalla SS w/ a D1 Procharger, on the Mustang he put down about 450hp and +/- 750 ftlb
This is one nasty 4400# car. He has a Denali SS w/ a blower that ran mid 13s if I remember correctly. (this is a 6600# AWD SUV) Impress people who don't know any better w/ a d-jet.
I'd be interested to see that same graph, but only comparing the AFR's. What does Lugo charge for dyno/tuning time?
I hope this helped.
I'm no professional... but I did stay at a Holiday Inn Express last night.
holy day ins lol cool thanx for the info. Does anyone know where rhey have one of those in south florida???????I hope this helped.
http://www.mustangdyne.com/LocatorPages/DynLoc_FL.htm
